User Data Does Not Load in the User Management Portal (Federated Account)
Issue Description:
The Users list in the User Management portal takes an unusually long time to load. After several minutes, the portal displays the message: “No Data Matches Criteria”
As a result, the Users list appears empty, even though users exist in the account.
Next Steps:
The Account Administrator or Co-Administrator must:
          1. Collect HAR logs from the browser while reproducing the issue.
2. Raise a support case through the Bentley Support Portal.
3. The Bentley IMS team will assist with the issue.
