Lab Configuration Pack Downloads
This page provides the necessary files for setting up and using OpenGround Lab capabilities. For a general overview of the lab capabilities, please refer to the Lab Guide.
Standard engineering Configuration Packs can be found here.
File Descriptions
Below is a description of each file type available for download.
Lab Configuration Pack (.hbp)
This is the primary file required to enable lab capabilities. It contains all the necessary components (data entry profiles, calculations, report templates) to create and use a laboratory project.
Publish Mapping (.csv)
This file maps data from your laboratory project to your engineering project during the "publish" workflow.
Example Project (.zip)
This file contains a set of CSV files for an example lab project. It serves as a valuable reference for how data should be entered for various test types.
Downloads
Config Pack Key Name Publish Mapping Example Project Notes
LAB_01.01 Laboratory LAB_01.01 Publish Mapping LAB_01.01 Example Project
