Python code to iterate a NamedGroupCollection
from MSPyBentley import * from MSPyECObjects import * from MSPyBentleyGeom import * from MSPyDgnPlatform import * from MSPyDgnView import * from MSPyMstnPlatform import * def iterate_named_groups(): """ Iterates through all NamedGroups in the active model and prints their names. """ ACTIVEMODEL = ISessionMgr.ActiveDgnModelRef if ACTIVEMODEL is None: print("No active DGN model found.") return # Create a NamedGroupCollection for the active model named_group_collection = NamedGroupCollection(ACTIVEMODEL) count = 0 for named_group in named_group_collection: name = named_group.GetName() print(f"NamedGroup {count}: {str(name)}") count += 1 if count == 0: print("No NamedGroups found in the active model.") if __name__ == "__main__": iterate_named_groups()
Python: Documentation | API Presentations | FAQs | GitHub | Samples | Wikis | Blogs
