Q. Can API input and execute analysis commands (e.g., `autopipe {filename.ntl} /o) used in the DOS?
Question:
Is it possible to input and execute Batch Processing commands (e.g., `autopipe {filename.ntl} /o`) used in the DOS prompt, from within Python?
Answer:
Not at this time, Dec 2025. This feature will be added into a future release of the program.
To be kept updated on this and any other IDEAs being added into AutoPIPE, please add your vote to the related IDEA or post a new IDEA here.
