Answer:
At this stage the program is trying to read autoplan.cnf file from the appdata folder. If there is a problem with reading this file, AutoPIPE will crash with no warning.
Suggest using steps below to reset the user's profile:
This should have resolved the issue.
If yes, happy day!
If no, please go to KB article here and follow the procedure.
