Can you write a script which defines a new Item Type library and adds
Item Type definitions with various property types (text, number, boolean)?
from MSPyBentley import * from MSPyECObjects import * from MSPyBentleyGeom import * from MSPyDgnPlatform import * from MSPyDgnView import * from MSPyMstnPlatform import * # This script creates a new Item Type Library and adds an Item Type with text, number, # and boolean properties. def CreateItemType(): # Define names for the library and item type item_type_lib_name = "CustomLibrary" item_type_name = "MyItemType" # Get the active DGN file dgn_file = ISessionMgr.GetActiveDgnFile() # Create a new Item Type Library item_type_lib = ItemTypeLibrary(item_type_lib_name, dgn_file, False) # Add a new Item Type definition item_type = item_type_lib.AddItemType(item_type_name, False) # Add a text property text_prop = item_type.AddProperty("Description", False) text_prop.SetType(CustomProperty.Type1.eString) text_prop.SetDefaultValue(ECValue("Default description")) # Add a number property (integer) int_prop = item_type.AddProperty("Count", False) int_prop.SetType(CustomProperty.Type1.eInteger) int_prop.SetDefaultValue(ECValue(0)) # Add a number property (double/float) float_prop = item_type.AddProperty("Length", False) float_prop.SetType(CustomProperty.Type1.eDouble) float_prop.SetDefaultValue(ECValue(0.0)) # Add a boolean property bool_prop = item_type.AddProperty("IsActive", False) bool_prop.SetType(CustomProperty.Type1.eBoolean) bool_prop.SetDefaultValue(ECValue(False)) # Write changes to the DGN file item_type_lib.Write() print(f"Item Type Library '{item_type_lib_name}' with Item Type '{item_type_name}' and properties created successfully.") def main(): CreateItemType() if __name__ == "__main__": main()
Python: Documentation | API Presentations | FAQs | GitHub | Samples | Wikis | Blogs
