Can you write a script which reads all ECInstances attached to a selected element
and prints their class names and property values?
from MSPyBentley import * from MSPyECObjects import * from MSPyBentleyGeom import * from MSPyDgnPlatform import * from MSPyDgnView import * from MSPyMstnPlatform import * def print_ecinstances_for_selected_element(): """ Reads all ECInstances attached to the first selected element and prints their class names and property values. """ sel_mgr = SelectionSetManager.GetManager() n_selected = sel_mgr.NumSelected() if n_selected == 0: print("No element selected. Please select an element.") return # Get the first selected element eh = ElementHandle() sel_mgr.GetElement(0, eh) if not eh.IsValid(): print("Selected element is not valid.") return # Set up EC query for all ECInstances on the element dgnECManager = DgnECManager.GetManager() scope_option = FindInstancesScopeOption() scope = FindInstancesScope.CreateScope(eh, scope_option) query = ECQuery.CreateQuery(ECQueryProcessFlags.eECQUERY_PROCESS_SearchAllIntrinsic) # Find ECInstances result_tuple = dgnECManager.FindInstances(scope, query) if not result_tuple or not result_tuple[0]: print("No ECInstances found on the selected element.") return for instance in result_tuple[0]: ec_class = instance.GetClass() class_name = ec_class.GetName() print(f"ECInstance Class: {class_name}") # Print all property values properties = ec_class.GetProperties(True) for prop in properties: prop_name = prop.GetName() ec_value = ECValue() instance.GetValue(ec_value, str(prop_name)) print(f" {prop_name}: {ec_value.ToString()}") print("-" * 40) def main(): print_ecinstances_for_selected_element() if __name__ == "__main__": main()
Python: Documentation | API Presentations | FAQs | GitHub | Samples | Wikis | Blogs
