Can you write a script which attaches another DGN file as a reference attachment,
prompting the user for the file and attachment settings (model logical name, and scale)?
from MSPyBentley import * from MSPyECObjects import * from MSPyBentleyGeom import * from MSPyDgnPlatform import * from MSPyDgnView import * from MSPyMstnPlatform import * import tkinter as tk from tkinter import filedialog, simpledialog def prompt_for_file(): """ Prompts the user to select a DGN file. :return: The path to the selected DGN file, or None if cancelled. """ root = tk.Tk() root.withdraw() file_path = filedialog.askopenfilename( title="Select a DGN file", filetypes=[("DGN files", "*.dgn")] ) root.destroy() return file_path def prompt_for_attachment_settings(): """ Prompts the user for attachment settings: model name, logical name, and scale. :return: (model_name, logical_name, scale) or (None, None, None) if cancelled. """ root = tk.Tk() root.withdraw() model_name = simpledialog.askstring("Attachment Settings", "Enter the model name to attach:") if model_name is None: root.destroy() return None, None, None logical_name = simpledialog.askstring("Attachment Settings", "Enter the logical name for the attachment:") if logical_name is None: root.destroy() return None, None, None scale = simpledialog.askfloat("Attachment Settings", "Enter the scale (e.g. 1.0):") root.destroy() if scale is None: return None, None, None return model_name, logical_name, scale def attach_dgn_file(file_path, model_name, logical_name, scale): """ Attaches a DGN file as a reference attachment to the active DGN model. """ ACTIVEMODEL = ISessionMgr.ActiveDgnModelRef if ACTIVEMODEL is None: print("No active DGN model found.") return moniker = DgnDocumentMoniker.CreateFromFileName(file_path) if moniker is None: print("Failed to create moniker from file path.") return ret = ACTIVEMODEL.CreateDgnAttachment(moniker, model_name, True) if BentleyStatus.eSUCCESS != ret[0]: print("Failed to create DGN attachment.") return attachment = ret[1] attachment.SetLogicalName(logical_name) attachment.SetStoredScale(scale) if BentleyStatus.eSUCCESS != attachment.WriteToModel(): print("Failed to write attachment to model.") return print("DGN file attached successfully.") def main(): file_path = prompt_for_file() if not file_path: print("No file selected.") return model_name, logical_name, scale = prompt_for_attachment_settings() if not model_name or not logical_name or scale is None: print("Invalid attachment settings.") return attach_dgn_file(file_path, model_name, logical_name, scale) if __name__ == "__main__": main()
Python: Documentation | API Presentations | FAQs | GitHub | Samples | Wikis | Blogs
