Python Assistant Prompts: Attach Cell Library and Place Cell
Prompt Used:
Can you write a script which prompts the user to select a cell library name and
cell name, then places that cell interactively?
Python Assistant Generated Code:
from MSPyBentley import *
from MSPyECObjects import *
from MSPyBentleyGeom import *
from MSPyDgnPlatform import *
from MSPyDgnView import *
from MSPyMstnPlatform import *
import tkinter as tk
from tkinter import filedialog, simpledialog
import os
# Tool class for interactive cell placement
class CellPlacementTool(DgnPrimitiveTool):
    def __init__(self, toolId, cellName, libraryPath):
        super().__init__(toolId, 0)
        self.cellName = cellName
        self.libraryPath = libraryPath
        self.m_self = self
    def _OnPostInstall(self):
        AccuSnap.GetInstance().EnableSnap(True)
        DgnPrimitiveTool._OnPostInstall(self)
    def _OnDataButton(self, ev):
        origin = ev.GetPoint()
        scale = DPoint3d(1, 1, 1)
        rotMatrix = RotMatrix()
        rotMatrix.InitIdentity()
        # Attach the cell library
        celLibraryName = BeFileName(self.libraryPath)
        Cell.AttachLibrary(fileName=BeFileName(), inputName=celLibraryName,
                           defaultDir=os.path.dirname(self.libraryPath), fromKeyin=0)
        # Find the cell in the library
        searchAll = 1  # => 0=no, 1=yes w/o messages, 2=yes w/ messages
        retVal, library = Cell.FindCell(None, self.cellName, searchAll)
        if BentleyStatus.eSUCCESS != retVal:
            print(f"Error finding cell {self.cellName} in library")
            return
        # Place the cell
        try:
            result = Cell.PlaceCell(
                origin=origin,
                scale=scale,
                trueScale=True,
                rotMatrix=rotMatrix,
                attributes=0,
                ggroup=0,
                relativeMode=False,
                baseLevel=0,
                sharedFlag=0,
                cellName=self.cellName,
                library=library
        except Exception as e:
            print(f"Error placing cell: {e}")
    def _OnResetButton(self, ev):
        self._OnRestartTool()
        return True
    def _OnRestartTool(self):
        CellPlacementTool.InstallNewInstance(self.GetToolId(), self.cellName, self.libraryPath)
    @staticmethod
    def InstallNewInstance(toolId, cellName, libraryPath):
        tool = CellPlacementTool(toolId, cellName, libraryPath)
        tool.InstallTool()
# Prompt user for cell library and cell name using tkinter
def select_cell_library_and_name():
    root = tk.Tk()
    root.withdraw()  # Hide the root window
    library_path = filedialog.askopenfilename(title="Select Cell Library",
                                              filetypes=[("Cell Library", "*.cel")])
    if not library_path:
        print("No library selected.")
        return
    cell_name = simpledialog.askstring("Cell Name", "Enter the cell name:")
    if not cell_name:
        print("No cell name entered.")
        return
    CellPlacementTool.InstallNewInstance(1, cell_name, library_path)
# Place Cell
def main():
# main
if __name__ == "__main__":
    main()
Python: Documentation | API Presentations | FAQs | GitHub | Samples | Wikis | Blogs
