Can you write a script which implements an interactive tool to copy
selected elements from a base point specified by the user?
from MSPyBentley import * from MSPyECObjects import * from MSPyBentleyGeom import * from MSPyDgnPlatform import * from MSPyDgnView import * from MSPyMstnPlatform import * # Interactive tool to copy selected elements from a base point to a new point specified by the user. class ElementCopyTool(DgnElementSetTool): def __init__(self, toolId): DgnElementSetTool.__init__(self, toolId) self.m_transform = Transform() self.m_transformr = Transform() self.m_dynamic = True self.base_point = None def _OnRestartTool(self): ElementCopyTool.s_instance = None ElementCopyTool.InstallNewInstance(self.ToolId) def _OnCleanup(self): ElementCopyTool.s_instance = None super()._OnCleanup() def _GetToolName(self, name): return WString("Copy Element") def _OnPostInstall(self): AccuSnap.GetInstance().EnableSnap(True) super()._OnPostInstall() NotificationManager.OutputPrompt("Identify base point for copy.") def _OnDataButton(self, ev): # First click: set base point if self.base_point is None: self.base_point = ev.GetPoint() NotificationManager.OutputPrompt("Identify destination point for copy.") return True # Second click: perform copy dest_point = ev.GetPoint() vec = DVec3d() vec.DifferenceOf(dest_point, self.base_point) self.m_transform.InitFrom(vec) self.m_transformr.InitFrom(DVec3d() - vec) self.m_dynamic = False # Copy all selected elements selection_mgr = SelectionSetManager.GetManager() num_selected = selection_mgr.NumSelected() if num_selected == 0: MessageCenter.ShowErrorMessage("No elements selected to copy.", "", False) self._OnRestartTool() return True for i in range(num_selected): eh = ElementHandle() selection_mgr.GetElement(i, eh) if not eh.IsValid(): continue # Duplicate the element and apply the transform eeh = EditElementHandle() eeh.Duplicate(eh) tInfo = TransformInfo(self.m_transform) handler = eeh.GetHandler(eMISSING_HANDLER_PERMISSION_Transform) if handler: handler.ApplyTransform(eeh, tInfo) eeh.AddToModel() MessageCenter.ShowInfoMessage("Elements copied.", "", False) self._OnRestartTool() return True def _OnResetButton(self, ev): SelectionSetManager.GetManager().EmptyAll() # Clear selection PyCommandState.StartDefaultCommand() return True @staticmethod def InstallNewInstance(toolId=1): # Check if elements are selected selection_mgr = SelectionSetManager.GetManager() num_selected = selection_mgr.NumSelected() if num_selected == 0: MessageCenter.ShowErrorMessage("No elements selected to copy.", "", False) return True tool = ElementCopyTool(toolId) tool.InstallTool() ElementCopyTool.s_instance = tool def main(): # To start the tool, call: ElementCopyTool.InstallNewInstance() if __name__ == "__main__": main()
Python: Documentation | API Presentations | FAQs | GitHub | Samples | Wikis | Blogs
