Can you write a script which selects all 3D solid or surface elements
whose volume falls within user-specified range?
from MSPyBentley import * from MSPyECObjects import * from MSPyBentleyGeom import * from MSPyDgnPlatform import * from MSPyDgnView import * from MSPyMstnPlatform import * import tkinter as tk from tkinter import simpledialog, messagebox def get_volume_range(): """Prompt user for min and max volume (in cubic meters) using tkinter.""" root = tk.Tk() root.withdraw() min_vol = simpledialog.askfloat("Volume Range", "Enter minimum volume (m³):", minvalue=0.0) if min_vol is None: return None, None max_vol = simpledialog.askfloat("Volume Range", "Enter maximum volume (m³):", minvalue=min_vol) if max_vol is None: return None, None return min_vol, max_vol def select_elements_by_volume_range(min_volume, max_volume): """ Selects all 3D solid or surface elements in the active model whose volume is within the specified range. Volumes are in cubic meters. """ ACTIVEMODEL = ISessionMgr.ActiveDgnModelRef dgnModel = ACTIVEMODEL.GetDgnModel() modelInfo = dgnModel.GetModelInfo() uorPerMeter = modelInfo.UorPerMeter graphicalElements = dgnModel.GetGraphicElements() selSetManager = SelectionSetManager.GetManager() selSetManager.EmptyAll() # Clear previous selection count = 0 for perElementRef in graphicalElements: eeh = EditElementHandle(perElementRef, dgnModel) msElement = eeh.GetElement() # Only process visible, graphical elements if not msElement.ehdr.isGraphics or msElement.hdr.dhdr.props.b.invisible: continue # Query for EC property 'Volume' dgnECManager = DgnECManager.GetManager() scopeOption = FindInstancesScopeOption() scope = FindInstancesScope.CreateScope(eeh, scopeOption) allQuery = ECQuery.CreateQuery(ECQueryProcessFlags.eECQUERY_PROCESS_SearchAllIntrinsic) instanceItr = dgnECManager.FindInstances(scope, allQuery) found = False for instance in instanceItr[0]: propValue = ECValue() instance.GetValue(propValue, 'Volume', 0) if not propValue.IsNull(): # Convert UOR³ to m³ volume = propValue.GetDouble() / (uorPerMeter ** 3) if min_volume <= volume <= max_volume: selSetManager.AddElement(perElementRef, dgnModel) count += 1 found = True break if not found: continue # Report results agenda = ElementAgenda() selSetManager.BuildAgenda(agenda) messagebox.showinfo
("Selection Complete", f"Selected {count} elements with volume in range [{min_volume}, {max_volume}] m³.") def main(): min_vol, max_vol = get_volume_range() if min_vol is not None and max_vol is not None: select_elements_by_volume_range(min_vol, max_vol) if __name__ == "__main__": main()
Python: Documentation | API Presentations | FAQs | GitHub | Samples | Wikis | Blogs
