Can you write a script which modifies the content of a selected text element?
Can you write a script which implements an interactive tool allowing the user to select
text element and edit its content in a dialog box?
from MSPyBentley import * from MSPyECObjects import * from MSPyBentleyGeom import * from MSPyDgnPlatform import * from MSPyDgnView import * from MSPyMstnPlatform import * import tkinter as tk from tkinter import simpledialog class TextEditTool(DgnElementSetTool): def __init__(self, toolId): """ Initialize the TextEditTool. :param toolId: Identifier for the tool. :type toolId: int """ DgnElementSetTool.__init__(self, toolId) self.m_self = self # Keep self reference def _OnDataButton(self, ev): """ Handle the data button event to select and edit a text element. :param ev: The event object containing information about the button event. :type ev: DgnButtonEvent :return: True if the event was handled successfully, False otherwise. :rtype: bool """ path = self._DoLocate(ev, True, ComponentMode.eInnermost) if not path: return False textEditElementHandle = EditElementHandle(path.GetHeadElem(), path.GetRoot()) if not textEditElementHandle.IsValid(): return False if textEditElementHandle.ElementType not in [7, 17]: print (f"Select a Text Element...") return False textQuery = textEditElementHandle.GetITextQuery() textPart = DimensionTextPartId.Create(0, eDIMTEXTPART_Primary, eDIMTEXTSUBPART_Main) textBlock = textQuery.GetTextPart(textEditElementHandle, textPart) if textBlock is None or textBlock.IsEmpty(): return False # Get the current text from the text block currentText = textBlock.ToString().GetWCharCP() # Open a dialog box to edit the text root = tk.Tk() root.withdraw() # Hide the root window newText = simpledialog.askstring("Edit Text", "Enter new text:", initialvalue=currentText) if newText is not None: # Update the text block with the new text textBlock.ReplaceText(newText, textBlock.CreateStartCaret(), textBlock.CreateEndCaret()) textEditElementHandle.GetElementDescr () # force load of element descr into editelementhandle # Create the element with the updated text block newTextElementHandle = EditElementHandle() if TextElemHandler.CreateElement(newTextElementHandle, textEditElementHandle, textBlock) ==
TextBlockToElementResult.eTEXTBLOCK_TO_ELEMENT_RESULT_Success: newTextElementHandle.ReplaceInModel(textEditElementHandle.ElementRef) MessageCenter.ShowInfoMessage("Text updated successfully.", "", False) else: MessageCenter.ShowErrorMessage("Failed to update text element.", "", False) else: MessageCenter.ShowErrorMessage("Text update canceled.", "", False) return True def _OnRestartTool(self): """ Restart the tool by installing a new instance of TextEditTool. :return: None """ TextEditTool.InstallNewInstance(self.ToolId) @staticmethod def InstallNewInstance(toolId): """ Create and install a new instance of the TextEditTool. :param toolId: Identifier for the tool. :type toolId: int """ tool = TextEditTool(toolId) tool.InstallTool() def main(): # To start the tool, call: TextEditTool.InstallNewInstance(1) if __name__ == "__main__": main()
Python: Documentation | API Presentations | FAQs | GitHub | Samples | Wikis | Blogs
