Buoyancy in Seastate vs Floation
Question
I observed differences in buoyancy between the Seastate (1422 MT) and the Flotation module (1459 MT). Can you please explain this?
Answer
There are a couple of reasons why you're seeing a difference in buoyancy values:
A. Seastate's Marine-Method Approximation
By default, Seastate uses the marine method, which treats each structural member as a submerged weight and applies that as a vertically distributed load along its length. In effect, Seastate does not directly compute the full displaced volume of plates "added weight", or non-modeled buoyant items. It only subtracts fluid weight from each member's self-weight, ignoring any plate or added buoyancy unless those items are modeled as separate elements or overridden on WEIGHT lines.
In your Seastate report (upright),
Total Buoyancy = 13951.954 kN, which converts to 13951.957 kN/9.81 = 1422 MT
B. Flotation's volume-based calculation, including plates and added buoyancy
Flotation computes the exact geometric volume of each member (and each plate) that lies below the waterplane and multiplies it by fluid density to obtain buoyancy. It then also adds any Added Buoyancy defined via WEIGHT lines (where you can specify non-modeled buoyant items and their submerged buoyancy) and the buoyancy contributed by all plates below the waterplane. As a result, Flotation's Total Buoyancy always includes:
In the Flotation report,
Member Buoyancy = 1456.847 MT
Plate Buoyancy = 3.196 MT
Added Buoyancy = 146.678 MT
Therefore, total Buoyancy = 1606.721 MT, which is > 1422 MT from Seastate.
Flotation's buoyancy is larger because:
C. Impact of FL/NF
In Flotation, by default, every plate (e.g mudmats, plates) that lies below the waterplane is automatically included in the volume-based integration.
In Seastate, if any members are left as non-flooded (NF), only their net-submerged weight is used. Flotation, however, assumes all members below the waterline flooded to the water surface (unless overridden) and so will compute full displaced volume accordingly.
Hence, if your Seastate input did not include any extra buoyant items, Seastate's marine method results (1422 MT) will undercount what Flotation (1606 MT) reports.
D. Orientation Shifts the waterplane intersection
When you rotate the jacket from upright to horizontal, some legs or members that were fully submerged in the upright orientation may now be only partially submerged (or may lie mostly above the waterplane when horizontal).
The net submerged length of each leg decreases, so the displaced volume and the buoyancy fall drastically.
In your Seastate report for the Horizontal Position, where the jacket's longitudinal axis is parallel to the waterplane,
Total Buoyancy Load = 11264.965 kN = 1148 T
Since the horizontal buoyancy (1148 T) < the jacket's weight (1360 T as per Flotation's weight report), the jacket sinks.
You need to ensure consistent input between the files for correct comparison:
