| Product(s): | ProStructures |
| Version(s): | CONNECT Edition (10.XX.00.XX) & 2023+ |
| Area: | Installation |
| Subarea: | Modify/Repair |
| Original Author: | Vyanktesh Nama, Bentley Global Technical Support |
Modifying or repairing ProStructures application from Control Panel seems not working.
In order to modify or repair the ProStructures application, we need to run the Setup file. Please follow the below steps to know the same.
1. Please find and run Setup_ProStructuresx64_xx.xx.xx.xx.exe file.
2. If you don't have this setup file, then download it from the Bentley Software Downloads site.
3. If you do not have access to download the application, then go to the location C:\ProgramData\Package Cache and search Setup_ProStructuresx64, you can find it in one of the folders.
4. Copy the setup file for which you wish to modify or repair the program and paste it somewhere like on the Desktop or Downloads folder.
5. Now, run this setup file and Modify or Repair as per your requirement.
This time, it will fetch the data from our server and will modify or repair the program.
