| Applies To |
| Product(s): |
AutoPIPE |
| Version(s): |
ALL; |
| Area: |
Crashes |
Date Logged & Current Version |
May. 2025 24.00.02.243 |
Problem:
Why Autopipe Material Library Editor Crashes or fails to Launch?
or
When I click the Material Library Editor icon on the toolbar, nothing happens. Why?
Try to open the application directly from the AUTOPIPELibraryEditor.exe file at this location:
C:\Program Files\Bentley\AutoPIPE 2024\APLibraryEditor
Does the file open after double clicking the EXE file?
- If no, the file does not open, then you have a permission issue / virus protection issue. That your IT will need to resolve.
- If yes, the file opens, first try rebooting the computer and then if that does not work consider completely uninstalling and reinstalling the application.
- If the issue persists, please contact the Bentley Technical Support team using the link provided here.
