CLPOP2 - Override Member Properties
Question
What is the 'Override Member Properties' in the CLPOP2 column 54 used for?
Answer
If the input properties of a given member differ from calculated properties, by default, the program sets the member to elastic and reports a warning message. When we enter 'C' on column 54 of the CLPOP2 line, SACS will override the input properties with calculated properties and assume the member as elastoplastic.
