WaterSight - Inconsistent Results for Affected Customers
Product(s): WaterSight
Area: Documentation
This article describes some potential issues the user might encounter while running operational events in WaterSight, such as Pipe breaks, fire events, pump shutdowns or valve operations.
Check valve issue
In case you are running a pipe break isolation run (the first step to identify affected customers, and before running a steady state or EPS model run) and you notice that the outage segments seem incorrectly defined, please confirm if you are using a check valve on the pipe next to a reservoir. If that is the case, adjust your WaterGEMS model by placing the check valve on the next-downstream pipe (rather than on the pipe directly adjacent to the reservoir), and then upload the updated model one again in WaterSight. This should solve the issue. We are working toward improvements of the handling of this situation.
Figure 1 - Pipe Break Isolation run results: customers with no water are displayed at red (for those withing the isolated pipe) and purple (for those downstream the isolated pipe)
Unbalanced time steps
In WaterSight the identification of affected customers only considers those that are directly impacted by the operational events. This means that the application always excludes chronical customers with issues - those that already had no water or low pressure before the event. The exact rules are the following:
If more than 50% of the time the results are unbalanced, the model will not calculate any customer affected and instead a warning message will be displayed informing the user.
Unbalaced model - Solving the issue
The issue can be solved by eliminating the root cause for the unbalanced time steps in WaterGEMS. Convergency errors can typically occur at pump storage or pressure/flow regulation valves. Other solutions that might help minimizing the issue pass to adjust the Calculation Options and decrease the "Accuracy" to 0.01 or to reduce the "Hydraulic timestep" (for example to 10 minutes or 5 minutes). It was also noted that selecting older Engines in the "Engine Compatibility" such as the WaterGEMS 2.00.10 might contribute to reduce the number of unbalanced time steps. Please note that reducing the Hydraulic timestep will always affect the performance of the model in WaterSight as it will take more time to run the operational events, so this should be done as last resource.
After the adjustments are done, upload the WaterGEMS model again in WaterSight (Administration >> Numerical Model).
Low pressure customers identified far away from the event location - and model is not unbalanced
WaterSight might identify low pressure customers located very far away from the event location, and which you might think should not be related with the event.
However please note that one of the conditions to identify the low pressure customers consists in checking those that were above the minimum pressure threshold (defined in the administration, under the service expectations tab) in the no event scenario and that during the event scenario end up with pressure below the threshold, during at least one time step of the all simulation period. This means that if the pressure threshold is for example 20 m, a small reduction from 20.5 to 19.5 m will mark that customer as low pressure. In conclusion, the event might be located very far away, it might cause a very small variation in the pressure, however that might be enough to make the pressure drop below the user defined threshold.
To check the pressure results at those customers, make sure to click on the node near the low pressure customers identified, and turn on the side by side view to compare the model results between the baseline scenario (no event) and the event scenario.
Below an example where the blue line (event scenario) goes below the 20 m pressure threshold, while in the event scenario (red line) the result is kept always above the 20 m pressure threshold.
Please note that the second condition to identify low pressure customers is the following:
- customers that were already below the minimum pressure in the baseline scenario (no event) but had a pressure decrease greater than 30% with the event, during at least one time step of the all simulation period: this means that a reduction from 5m to 3.5m would also make this customer to get identified as low pressure.
Affected customers are not calculated
The first thing to check is if customer meter elements exist in the uploaded WaterGEMS model (in Admin >> Numerical Model). This is required so that customers can be identified in the operational response simulation module of WaterSight.
If after running a steady state or EPS run for a pipe break simulation, fire event, pump shutdown or valve operations event you get a warning message mentioning that more than 50% of the timesteps are unbalanced, than WaterSight will not calculate and display the affected customers as the results could be invalid (see above for more detail). In this case the user should improve the WaterGEMS model in order to reduce the number of unbalanced timesteps, before deciding to upload it in WaterSight.
Also note that in some cases the events might not cause any impact in the system in terms of affected customers (for example if there is still enough tank storage during the simulation period, or fire flow or burst flow is very small, etc).
Operational Response Simulation
