The SACS development team is pleased to announce the release of SACS 2024 (24.00.04).
SACS 2024 (24.00.04) Release Highlights
Precede Bug Fix
Removed unintentional access to AISC 16th edition design code check options from Precede which was causing Precede to crash when the Analysis Options command was selected.
List of Fixed Defects
SACS
- 1572566 - Removed unintentional access to AISC 16th edition design code check options from Precede and Datagen.
Dynamic Response
- 1568785 - Fixed an issue where Dynamic Response would crash when non-structural (dummy or appurtenance) elements were included in the structural model.
