| Product(s): | ProStructures (ProSteel) |
| Version(s): | CONNECT Edition (10.XX.00.XX) & 2023+ |
| Area: | Positionflags & Positioning |
| Subarea: | Others tab |
| Original Author: | Vyanktesh Nama, Bentley Global Technical Support |
How to delete all assigned Part Numbers?
Enter methods to resolve in this section.
1. Open Positionflags and Positioning tool located at Steel Workflow > Drawing Production > Positionflags and Positioning.
2. Go to the Others tab and under Delete/Fix section select your desire options say Single Parts and Groups and click on the delete icon that appears.
3. A window will appear in which you can Choose all or Filter the objects as per your requirement.
