MicroStation Python: Create a User Interface
Introduction
In this wiki, we'll delve into the world of MicroStation Python development, specifically focusing on crafting a user interface (UI) using the TKINTER library. This powerful combination allows you to create custom dialogs and tools within the MicroStation environment, enhancing productivity and user experience.
Before we dive into the code, it's essential to understand that TKINTER is a standard Python library for creating graphical user interfaces. It's relatively easy to learn and use, making it a popular choice for rapid UI development.
Refer to the Python Editor wiki to create and load a python project. Name your project as "DialogDemo.py" and save it to your preferred directory. Open the project in the editor for writing your Python script.
Understanding the Code
Let's break down the Python code step-by-step:
Import Modules
The script begins by importing several modules for interacting with MicroStation and creating the TKINTER UI:
   colorchooser: A TKINTER module for selecting colors.
from MSPyBentley import *
from MSPyBentleyGeom import *
from MSPyECObjects import *
from MSPyDgnPlatform import *
from MSPyDgnView import *
from MSPyMstnPlatform import *
import ctypes
from tkinter import *
from tkinter import colorchooser
Defining Functions
Creating the UI
The main function constructs the TKINTER UI:
Key Points
Here is the complete script
import ctypes
root = Tk()
# Message box function
def MsgBox (title, text, style):
    return ctypes.windll.user32.MessageBoxW (0, text, title, style)
# RGB to String function
def rgb_to_string(rgb_tuple):
    return ', '.join(map(str, rgb_tuple))
# Hex to RGB function
def hex_to_rgb(hex_color):
    # Remove the hash symbol if present
    hex_color = hex_color.lstrip('#')
    # Convert hex to RGB
    rgb = tuple(int(hex_color[i:i+2], 16) for i in (0, 2, 4))
    return rgb
# Get Level Name List
def GetLevelList ():
    level_List = []
    ACTIVEMODEL = ISessionMgr.ActiveDgnModelRef
    levelCache = ACTIVEMODEL.GetDgnFile().GetLevelCache()
    it = iter(levelCache)
    for level in it:
        levelName = level.GetName()
        level_List.append(levelName)
    return level_List
# Place Line Button
def PlaceLine():
    global my_color
    global selected_level
    if my_color is None:
        my_color = "#646464"
    rgb_color = hex_to_rgb(my_color)
    rgb_str = rgb_to_string (rgb_color)
    level_name = str(selected_level.get())
    keyin_str = "ACTIVE COLOR " + rgb_str + "; ACTIVE LEVEL " + level_name
    keyin_str = keyin_str + "; ACTIVE WEIGHT 2; PLACE LSTRING"
    #print(keyin_str)
    PyCadInputQueue.SendKeyin(keyin_str)
    root.destroy()
# Get color function
def GetColor():
    global my_color
    global color_label1
    my_color = colorchooser.askcolor()[1]
    my_color = my_color.upper()
    color_label1.config(text=my_color)
    color_label1.config(bg=my_color)
# Main function
def main():
    global my_color
    global color_label1
    #root = Tk()
    root.title("Dialog Demo...")
    # Color
    # Create the widgets
    color_label = Label(root, text="Color: ")
    color_label1 = Label(root, text=my_color, bg=my_color)
    color_button = Button(root, text="Pick A Color", command=GetColor)
    # Use grid to place the widgets
    color_label.grid(row=0, column=0, padx=10, pady=10, sticky="ew")
    color_label1.grid(row=0, column=1, padx=10, pady=10, sticky="ew")
    color_button.grid(row=0, column=2, padx=10, pady=10, sticky="ew")
    # Level
    levelList = GetLevelList ()
    level_label = Label(root, text="Level: ")
    selected_level = StringVar()
    selected_level.set(levelList[0])
    level_option = OptionMenu(root, selected_level, *levelList)
    level_label.grid(row=1, column=0, padx=10, pady=10, sticky="ew")
    level_option.grid(row=1, column=1, padx=10, pady=10, sticky="ew")
    place_button = Button(root, text="Place Line", command=PlaceLine)
    place_button.grid(row=2, column=1, padx=10, pady=10, sticky="ew")
    # Configure column weights to spread out evenly
    root.grid_columnconfigure(0, weight=1)
    root.grid_columnconfigure(1, weight=1)
    root.grid_columnconfigure(2, weight=1)
    root.mainloop()
if __name__ == "__main__":
    main()
Run/Execute project
Select project "DialogDemo.py" from the Python Editor dialog and Run/Execute the python script.
The following UI loads allowing User to create a Line String element with the selected Color,  Level properties.
A screenshot of a computer programDescription automatically generated
Explore additional TKINTER widgets and layout options to create more complex and visually appealing UIs with MicroStation integration.
Happy coding!
Python: Documentation | API Presentations | FAQs | GitHub | Samples | Wikis | Blogs
