MicroStation Python: Add Keyins to your Program
Welcome to the world of MicroStation Python! Enhancing your application's functionality with key-in command support allows users to execute custom commands. In this wiki, we will guide you through the process of adding key-in command support to MicroStation using Python.
Add Keyin Command Support
Let us dive into creating and registering key-ins within MicroStation. Refer to the Python Editor wiki to create and load a python project. Name your project as "MyReport.py" and save it to your preferred directory. Open the project in the editor for writing your Python script.
Building the XML Command Table
First, we need to create an XML command table named MyReport.commands.xml. This XML file will define the commands that we want to add to MicroStation. The format of the XML file is well-documented in the link Adding Commands to Add-ins.
The XML file defines three commands: ReportLevels, ReportTextStyles and ReportFonts each associated with a keyin string. Below is a fully completed example of the XML command table.
<?xml version="1.0" encoding="utf-8" ?>
<KeyinTree xmlns="http://www.bentley.com/schemas/1.0/MicroStation/AddIn/KeyinTree.xsd">
    <RootKeyinTable ID="root">
        <Keyword SubtableRef="MyDgnReport" CommandClass="MacroCommand"
                 CommandWord="MYREPORT">
            <Options Required="true" />
        </Keyword>
    </RootKeyinTable>
    <SubKeyinTables>
        <KeyinTable ID="MyDgnReport">
            <Keyword CommandWord="LEVELS" />
            <Keyword CommandWord="TEXTSTYLES" />
	    <Keyword CommandWord="FONTS" />
        </KeyinTable>
    </SubKeyinTables>
    <KeyinHandlers>
        <KeyinHandler Keyin="MYREPORT LEVELS"           Function="ReportLevels" />
        <KeyinHandler Keyin="MYREPORT TEXTSTYLES"	Function="ReportTextStyles" />
		<KeyinHandler Keyin="MYREPORT FONTS"	Function="ReportFonts" />
    </KeyinHandlers>
</KeyinTree>
Loading the Command Table in Python
Next, we will load the command table into our Python program. MicroStation provides a PythonKeyinManager class with an API LoadCommandTableFromXml to register the command table.
Import Modules
The script begins by importing several modules offering functions and classes to interact with MicroStation.
from MSPyBentley import *
from MSPyBentleyGeom import *
from MSPyECObjects import *
from MSPyDgnPlatform import *
from MSPyMstnPlatform import *
from MSPyDgnView import *
import os
import ctypes
Message Box Function
The MsgBox function is a utility to display message boxes. It uses the ctypes library to call the Windows API for message boxes.
def MsgBox (title, text, style):
    return ctypes.windll.user32.MessageBoxW (0, text, title, style)
Report Functions
The ReportLevels, ReportTextStyles and ReportFonts functions are placeholders (stubs) that currently display a message box indicating that the function is a work in progress (WIP).
def ReportFonts ():
    print ("Report Fonts stub...")
    MsgBox ('MyReport', 'WIP: This function will report existing Fonts...', 0)
def ReportTextStyles ():
    print ("Report Text Styles stub...")
    MsgBox ('MyReport', 'WIP: This function will report existing Text Styles...', 0)
def ReportLevels ():
    print ("Report Levels stub...")
    MsgBox ('MyReport', 'WIP: This function will report existing Levels...', 0)
Putting it all Together: The main Function
The main function constructs the path to the XML command table and uses the PythonKeyinManager to load the command table into MicroStation. The WString function is used to convert the file paths to the appropriate string format required by the API.
Here is the complete script.
import os
import ctypes
# Message box function
    ##  Styles:
    ##  0 : OK
    ##  1 : OK | Cancel
    ##  2 : Abort | Retry | Ignore
    ##  3 : Yes | No | Cancel
    ##  4 : Yes | No
    ##  5 : Retry | Cancel
    ##  6 : Cancel | Try Again | Continue
    ## To also change icon, add these values to previous number
    # 16 Stop-sign icon
    # 32 Question-mark icon
    # 48 Exclamation-point icon
    # 64 Information-sign icon consisting of an 'i' in a circle
# Report fonts function
def ReportFonts ():
# Report text styles function
# Report levels function
# Main function
def main():
    keyinXml = os.path.dirname(__file__) + '/MyReport.commands.xml'
    PythonKeyinManager.GetManager ().LoadCommandTableFromXml
                                     (WString (__file__), WString (keyinXml))
# main
if __name__ == "__main__":
    main()
Run/Execute project
Select project "MyReport.py" from the Python Editor dialog and Run/Execute the python script.
In the MicroStation Key-in window, type MyReport Levels and the following Message box will be displayed.
Extend the above code to add the reporting functionalities. Refer to the delivered examples and documentation.
Happy coding!
Python: Documentation | API Presentations | FAQs | GitHub | Samples | Wikis | Blogs
