MicroStation Python: Create Basic Elements
Welcome to the world of MicroStation Python! In our earlier wikis, we explored how to create Line and Line String elements. In this wiki, we will delve into creating other basic geometric elements in MicroStation using Python.
Create Basic Elements in MicroStation using Python
Let us dive into creating basic geometric elements such as Arc, Circle, Ellipse, and Shape using Python. Refer to the Python Editor wiki to create and load a python project. Name your project as "CreateBasicElements.py" and save it to your preferred directory. Open the project in the editor for writing your Python script.
Import Modules
The script begins by importing several modules offering functions and classes to interact with MicroStation and to create geometric elements.
import math
from
MSPyBentley import * from MSPyBentleyGeom import * from MSPyECObjects import * from MSPyDgnPlatform import * from MSPyDgnView import * from MSPyMstnPlatform import *
Create an Arc Element
The createArcElement() function takes several parameters for the arc element, including the base point, radius, rotation, start angle, and sweep angle. It uses the ArcHandler.CreateArcElement() method to create the arc element with these parameters. The script includes error checking to ensure the arc element is successfully created and added to the model.
def createArcElement(basePoint, radius=100, rotation=math.pi/4,
                       startAngle=0, sweepAngle=math.pi/2):
    global ACTIVEMODEL
    arc_eeh = EditElementHandle()
    axis1 = axis2 = radius
    # Create Arc element
    status = ArcHandler.CreateArcElement(arc_eeh, None, basePoint, axis1, axis2,
                                            rotation, startAngle, sweepAngle,
                                            ACTIVEMODEL.Is3d(), ACTIVEMODEL)
    if BentleyStatus.eSUCCESS != status:
        return False
    # Add the Arc element to model
    if BentleyStatus.eSUCCESS != arc_eeh.AddToModel():
        return False
    return True
Create a Circle Element
The createCircleElement() function takes base point and radius as parameters for the circle element. It uses the EllipseHandler.CreateEllipseElement() method to create the circle element. The script includes error checking to ensure the circle element is successfully created and added to the model.
def createCircleElement(basePoint, radius=50):
    global ACTIVEMODEL
    circle_eeh = EditElementHandle()
    ell = DEllipse3d.FromCenterRadiusXY(basePoint, radius)
    # Create Ellipse element
    status = EllipseHandler.CreateEllipseElement(circle_eeh, None, ell,
                                                    ACTIVEMODEL.Is3d(),
                                                    ACTIVEMODEL)
        return False
    # Add the Ellipse element to model
    if BentleyStatus.eSUCCESS != circle_eeh.AddToModel():
        return False
    return True
Create an Ellipse Element
The createEllipseElement() function takes base point, radius and rotation as parameters for the ellipse element. It uses the EllipseHandler.CreateEllipseElement() method to create the ellipse element. The script includes error checking to ensure the ellipse element is successfully created and added to the model.
def createEllipseElement(basePoint, radius=100, rotation=0):
    global ACTIVEMODEL
    ellipse_eeh = EditElementHandle()
    axis2 = radius
    axis1 = axis2 / 2
    status = EllipseHandler.CreateEllipseElement(ellipse_eeh, None,
                                                    basePoint,
                                                    axis1, axis2,
                                                    rotation,
                                                    ACTIVEMODEL.Is3d(),
                                                    ACTIVEMODEL)
        return False
    if BentleyStatus.eSUCCESS != ellipse_eeh.AddToModel():
        return False
    return True
Create a Shape Element
The createShapeElement() function generates a shape element at a given base point. It defines and sets the necessary coordinates, then uses the ShapeHandler.CreateShapeElement() method to create the shape element. The script includes error checking to ensure the shape element is successfully created and added to the model.
def createShapeElement(basePoint):
    global ACTIVEMODEL
    shape_eeh = EditElementHandle()
    # Set Shape coordinates
    offset = 150
    points = DPoint3dArray()
    points.append (DPoint3d (basePoint.x, basePoint.y, 0.0))
    points.append (DPoint3d (basePoint.x + offset, basePoint.y, 0.0))
    points.append (DPoint3d (basePoint.x + offset, basePoint.y + offset, 0.0))
    points.append (DPoint3d (basePoint.x, basePoint.y + offset, 0.0))
    # Create Shape element
    status = ShapeHandler.CreateShapeElement (shape_eeh, None, points,
        return False
    # Add the Shape element to model
    if BentleyStatus.eSUCCESS != shape_eeh.AddToModel():
        return False
    return True
Putting it all Together: The main Function
The main function initializes the active model and calls the functions to create the geometric elements.
Here is the complete script.
import math
from
MSPyBentley import * from MSPyBentleyGeom import * from MSPyECObjects import * from MSPyDgnPlatform import * from MSPyDgnView import * from MSPyMstnPlatform import * # Create Shape Element function def createShapeElement(basePoint): global ACTIVEMODEL shape_eeh = EditElementHandle() # Set Shape coordinates offset = 150 points = DPoint3dArray() points.append (DPoint3d (basePoint.x, basePoint.y, 0.0)) points.append (DPoint3d (basePoint.x + offset, basePoint.y, 0.0)) points.append (DPoint3d (basePoint.x + offset, basePoint.y + offset, 0.0)) points.append (DPoint3d (basePoint.x, basePoint.y + offset, 0.0)) points.append (DPoint3d (basePoint.x, basePoint.y, 0.0)) # Create Shape element status = ShapeHandler.CreateShapeElement (shape_eeh, None, points, ACTIVEMODEL.Is3d(), ACTIVEMODEL) if BentleyStatus.eSUCCESS != status: return False # Add the Shape element to model if BentleyStatus.eSUCCESS != shape_eeh.AddToModel(): return False return True # Create Ellipse Element function def createEllipseElement(basePoint, radius=100, rotation=0): global ACTIVEMODEL ellipse_eeh = EditElementHandle() axis2 = radius axis1 = axis2 / 2 # Create Ellipse element status = EllipseHandler.CreateEllipseElement(ellipse_eeh, None, basePoint, axis1, axis2, rotation, ACTIVEMODEL.Is3d(), ACTIVEMODEL) if BentleyStatus.eSUCCESS != status: return False # Add the Ellipse element to model if BentleyStatus.eSUCCESS != ellipse_eeh.AddToModel(): return False return True # Create Circle Element function def createCircleElement(basePoint, radius=50): global ACTIVEMODEL circle_eeh = EditElementHandle() ell = DEllipse3d.FromCenterRadiusXY(basePoint, radius) # Create Ellipse element status = EllipseHandler.CreateEllipseElement(circle_eeh, None, ell, ACTIVEMODEL.Is3d(), ACTIVEMODEL) if BentleyStatus.eSUCCESS != status: return False # Add the Ellipse element to model if BentleyStatus.eSUCCESS != circle_eeh.AddToModel(): return False return True # Create Arc Element function def createArcElement(basePoint, radius=100, rotation=math.pi/4, startAngle=0, sweepAngle=math.pi/2): global ACTIVEMODEL arc_eeh = EditElementHandle() axis1 = axis2 = radius # Create Arc element status = ArcHandler.CreateArcElement(arc_eeh, None, basePoint, axis1, axis2, rotation, startAngle, sweepAngle, ACTIVEMODEL.Is3d(), ACTIVEMODEL) if BentleyStatus.eSUCCESS != status: return False # Add the Arc element to model if BentleyStatus.eSUCCESS != arc_eeh.AddToModel(): return False return True # Main function def main(): # Global variable declaration global ACTIVEMODEL # Get the active DGN model reference ACTIVEMODEL = ISessionMgr.ActiveDgnModelRef if ACTIVEMODEL is None: return if True != createArcElement(DPoint3d(0, 0, 0)): print("Create Arc element failed...") if True != createCircleElement(DPoint3d(200, 0, 0)): print("Create Circle element failed...") if True != createEllipseElement(DPoint3d(400, 0, 0)): print("Create Ellipse element failed...") if True != createShapeElement(DPoint3d(600, -75, 0)): print("Create Shape element failed...") PyCadInputQueue.SendKeyin("FIT VIEW EXTENDED") if __name__ == "__main__": main()
Run/Execute project
Select project "CreateBasicElements.py" from the Python Editor dialog and Run/Execute the python script.
Voila! An arc, circle, ellipse, and shape element have been successfully created and added to your active MicroStation model.
Enhance the above code to add a fill property to a closed element by referring to the provided examples and documentation.
Happy coding!
Python: Documentation | API Presentations | FAQs | GitHub | Samples | Wikis | Blogs
