When working on complex projects in MicroStation, organizing different elements into levels can enhance efficiency and clarity. This guide will walk you through creating a new level programmatically using Python.
The script begins by importing several modules offering functions and classes to interact with MicroStation.
from MSPyBentley import * from MSPyBentleyGeom import * from MSPyECObjects import * from MSPyDgnPlatform import * from MSPyDgnView import * from MSPyMstnPlatform import *
The core of our script is the createLevel() function, which checks if the level already exists and creates if not. It then writes the changes to the level cache.
def createLevel(levelName):
1. Active DGN File
The first step is to obtain the active design file, which is the file you are currently working on in MicroStation.
dgnFile = ISessionMgr.GetActiveDgnFile() if dgnFile is None: return False
2. Retrieve the Level Cache
Next retrieve level cache from active design file.
levelCache = dgnFile.GetLevelCache() if levelCache is None: return False
3. Check if Level Name exists.
If Level Name exists in the design file, get the Level Handle.
LevelHandle = levelCache.GetLevelByName(levelName)
4. Create New Level
If Level Name is not in the design file, create the new Level and write the changes to the level cache.
if not LevelHandle.IsValid(): LevelHandle = levelCache.CreateLevel(levelName, LEVEL_NULL_CODE, LEVEL_NULL_ID) if not LevelHandle.IsValid(): return False levelCache.Write()
5. Return Level ID
Finally, return the Level ID, which confirms that the level creation is successful.
return LevelHandle.GetLevelId()
To create multiple levels, we can use a loop within the main function. This loop creates ten levels named "Level_1" through "Level_10" and opens the Level Manager dialog. With this function, you can now add new levels to your MicroStation model with ease, keeping your project organized and manageable.
def main(): for i in range(1, 11): sLevelName = "Level_" + str(i) iLevelId = createLevel(sLevelName) PyCadInputQueue.SendCommand("LEVELMANAGER DIALOG OPEN")
Here is the complete script.
import os import math import sys from MSPyBentley import * from MSPyBentleyGeom import * from MSPyECObjects import * from MSPyDgnPlatform import * from MSPyDgnView import * from MSPyMstnPlatform import * # Create Level Function def createLevel(levelName): # Get Active DGN File dgnFile = ISessionMgr.GetActiveDgnFile() if dgnFile is None: return False # Get Level Cache from DGN File levelCache = dgnFile.GetLevelCache() if levelCache is None: return False # If Level Name exists, get Level Handle LevelHandle = levelCache.GetLevelByName(levelName) # If Level Handle is invalid, create Level if not LevelHandle.IsValid(): # Create New Level LevelHandle = levelCache.CreateLevel(levelName, LEVEL_NULL_CODE, LEVEL_NULL_ID) if not LevelHandle.IsValid(): return False # Write Level Cache changes levelCache.Write() # Return Level ID of newly created Level return LevelHandle.GetLevelId() # Main Function def main(): # Create Levels 1 to 10 for i in range(1, 11): sLevelName = "Level_" + str(i) print (sLevelName) # Call the createLevel function iLevelId = createLevel (sLevelName) print (iLevelId) PyCadInputQueue.SendCommand("LEVELMANAGER DIALOG OPEN") if __name__ == "__main__": print ("Create Levels...") main()
Extend the above code to include CRUD (Create, Read, Update, Delete) Level operations by exploring the documentation.
Happy coding!
