10. Static Analysis Enhancements & Defects for AutoPIPE
Note: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested:
Feature 812752
Fatigue analysis procedure for EN13480
Feature 812752
Completely stop analysis midstream regardless  number of load cases or analysis sets remaining
Feature 761843
Increase the number of Support group numbers for the selected SAM case and support(s) to 500 or unlimited
Feature 645049
Add option to Release / Unlock anchor for hydrotest analysis
TFS-E 1088674
Add feature to perform analysis across multiple models that are connected
TFS-E 673219
Increase number of Static Seismic Earthquake load cases
TFS-D 407514
Material properties set for valve or flexible joint are used to calculate allowable stress for pipe that follows
TFS-353620:
Change the default order of the ASME NB Static analysis set
TFS-D 169522
Frictional Seismic Loads on Supports Wrong
TFS-E 113620:
Add feature to Import / Export Static analysis sets from model
TFS-E 110599 (CAE-CR-3268):
Add fatigue analysis for ASME piping codes
TFS-E 82441:
TFS-E 80939:
Non linear analysis for hydrotest condition
CAE-CR-9970:
Allow user to specify OCC case as an initial state for another OCC case
Enhancements Requests and Logged Defects
