"Stress Summary" sub-report using Results> Output Report in AutoPIPE
Comments, Questions, and Answers:
Note: For additional information about Stress Summary report beyond that in the AutoPIPE help, see the following "AutoPIPE_ASME_NB_Example.pdf" Document that was copied to your computer when the software was installed:
Location is dependent upon the version of AutoPIPE Installed:
AutoPIPE V8 09.06.xx.xx and higher: C:\Bentley\AutoPIPE V8i SELECTseries \Documents\
AutoPIPE V8i 09.05.01.05 and lower: C:\Bentley\AutoPIPE V8i SELECTseries \Examples\
  1. Difference in hand calculation vs software results for thermal range ratchet
  2. When fatigue data is off the tabulated stress tables
  3. Error message "Stress ratio results for this section are zero."
  4. Stress Summary settings does not appear to be using the envelope WIND load case combination in Eq. 9
  5. Results for Eq.10b in Stress Summary Output are always zero
  6. ASME NC/ND Stress Summary with Reversing dynamic loads actually means...
  7. Does AutoPIPE's Stress Summary> Reversing Dynamic option consider both +ve and -ve dynamic loads?
  8. Combination dropdown load case names: Hydrotest and Hydrotest-(NL)
  9. Fatigue report indicates 15inf, why?
Sub-reports FAQ
