| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Technical Support |
| Date Logged | Jan. 2019 |
How to open Bentley CONNECTION Center?
There are 4 methods to open CONNECTION Center
1: From AutoPIPE
2: From CONNECT Client
3. From Bentley.com
4. Directly
Open AutoPIPE, select "silhouette" icon in upper right corner of the application and press on CONNECTION Center command as shown below
Open CONNECTION Client and click on CONNECTION Center command
Open web browser and enter the following web page: www.bentley.com
a. Sign Into the web site using your credentials
b. Select Support from the Top
c. Scroll down the page and select the Go To CONNECTION Center hyperlink
Enter address into your internet browser: https://connect.bentley.com/
Note -
502 Bad Gateway error message
When attempting to reach https://connect.bentley.com/, error message above appears. This may be due to an IMS (Identity Management System) issues. Bentley's support team is currently working to resolve the issue. Please wait 1 hour, if the problem persists then contact Bentley
Continue to log a Service Request
