| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Settings |
| Date Logged & Current Version |
Sept. 2016 10.01.00.09 |
When panning and zooming in the program default Beep is sounded, why and how to avoid?
This default beep sound is played because the user has issued a command before the previous command was completed by the program. Hence the default Beep sound is played.
Option #1: Ignore it and continue working.
Option #2: Slow down while panning and zooming to give the computer time to finish rendering the entire image before initiating the next command.
Option #3: Turn off the computer default beep sound, see youtube video for instructions
Note:
If you like to see a feature to shut off this sound from within AutoPIPE, please add your Vote to the IDEA here. After adding your vote, you will be updated on when this feature will be added into AutoPIPE. Also consider adding comments on an IDEA to get timely responses directly from the AutoPIPE Development team / Product Manager.
