EasyPower FAQ - New Licensing Information
EasyPower New Licensing Information
Starting with EasyPower 2024, we are using the Bentley Subscription Entitlement Service (SES) licensing technology. There are many benefits to this new licensing and a few steps to get you and your company transitioned to it, especially if your company doesn't already use other Bentley products.
Note: New Version Numbering. In order to align with the naming convention of the Bentley products, we are shifting to a system that is based on the year it is released.
Benefits of the New Licensing System
The new licensing system has account-based access, rather than license keys, serial numbers, or authorization codes. There will no longer be a need for license servers or complicated VM setups to access the software on multiple computers.
Glossary
With the new licensing system, it will be helpful for you to familiarize yourself with the following terms.
Next Steps - What Do I Do Now?
In order for current EasyPower users to download the latest version of EasyPower 2024, you will need to create or sign in to a Bentley user account, if you don't already have one. Follow the flow chart below to see which steps apply to your situation. (click the image below to see the full resolution image)
Ses-activation ses-user-quickstart-guide CONNECT-center-overview software-downloads find-adminitrator administrator-process ses-user-quickstart-guide2
Frequently Asked Questions
Why is EasyPower Licensing changing?
As a part of our integration into Bentley Systems, we’re updating our licensing technology to better serve our customers. This upgrade to Bentley's Subscription Entitlement Service (SES) will provide new ways of accessing, managing, and using the EasyPower software.
What is Bentley’s Subscription Entitlement Service (SES)?
License entitlements, which are granted and maintained through user management in the Bentley CONNECT Center, replace the serial numbers and site activation keys (SL, HL, and Cloud) used in previous versions of EasyPower. Your sign-in to the Bentley CONNECTION Client validates your use of the software and provides enhanced security for your Bentley licenses and subscriptions.
How will this impact my current software?
If you’re using Easypower 11.0 or earlier, you will not see a change in the way you access your software. Easypower 2024 will be the first product version available on Bentley’s Subscription Entitlement Service (SES).
I own a perpetual product; how does this affect me?
You will retain ownership of your perpetual licenses. The latest version, EasyPower 2024, will be available only with Bentley's SES licensing technology.
What is a SELECT Subscription?
With perpetual licenses, Bentley refers to the yearly maintenance payment as a subscription to SELECT. Your SELECT subscription for maintenance offers many of the same benefits as your are accustomed to (software updates, technical support, and library updates) as well as some new benefits. More information here: https://www.bentley.com/support/licensing-and-subscriptions/
Can I upgrade to EasyPower 2024 without upgrading to SES licensing?
No, starting with EasyPower 2024, all EasyPower programs will operate with SES licensing technology.
Can I upgrade to EasyPower 2024 without creating a Bentley login?
No. SES licensing is account-based and requires users to log in and be affiliated with an account to access licenses. Please refer to the licensing flowchart to get started.
Is there an offline mode?
Yes, Easypower can still be used when disconnected from the internet. However, offline policies are set and managed by your organization. For additional information, please reach out to your organization’s administrator. More Info - License Checkouts.
Can users still check out a license?
Yes. This can be done by the administrator via the Entitlement Management Service or by the user in the Bentley Licensing Tool. More information.
Can I see who is currently using licenses?
Account Administrators will be able to see the names of users who are running licenses.  Users will not be able to see this information.
I tried to download EasyPower 2024, but received a “Non-SELECT” error message. How do I gain access?
Please reach out to us at the Bentley Support Portal to complete a SELECT acknowledgement form.
I was issued a Trial when opening EasyPower 2024, how do I access my license instead?
To access your EasyPower license, you will need to use the Feature Level Selector when installing the program. After downloading EasyPower 2024:
Note: you should only need to make this selection one time, unless you need to change active licenses.
I logged into my Bentley account, but do not see my EasyPower entitlements. What should I do?
There may be additional steps required to complete the account step up or a correction needed. Please go to the Bentley Support Portal to get assistance.
Why am I unable to submit a service request on the Bentley support portal?
If you are NOT associated to an account, you will not have the ability to submit a service request.
I am not the Administrator, how do I become associated to my account?
Contact your Administrator to add you to the account. If you are unable to contact your Administrator, reach out to the Bentley Support Portal.
How do I update my account Administrator if they no longer work for my company or simply shouldn’t be associated with my account?
You will need to provide a letter on company letterhead stating who the new administrator should be. Letter should include: full name, email, and business justification for change.
 If you are unable to submit the request to the User Admin Support yourself, please contact the Bentley Support Portal for help with the request..
How can I have EasyPower 2024 added to my company’s E365 subscription?
Account Administrators will need to contact their Enterprise Success Manager or their Account Manager to have their EasyPower license(s) added to their E365 program.
 Should I submit a service ticket through Bentley Support?
Yes, effective Feb. 28, 2025, you should contact the Bentley Support Portal to submit a support ticket.
I called the EasyPower Support phone line, but no one answered. How do I get support?
We are currently experiencing I high volume of support cases and phone calls. If you do call, please leave a voicemail for one of our team members to give you a call back.
