SYNCHRO 4D Pro 2024 (v6.5.4) Release Announcement
Quick links:
Upgrading and Downloads:
If you have existing cloud-hosted 4D SYNCHRO Control projects, see the detailed instructions on upgrading cloud-hosted projects from 2021 (v6.4) to 2024 (v6.5)
If you are starting your first cloud-hosted SYNCHRO Control project, see Collaborating on a cloud-hosted 4D project.
Click the links below to download the latest version or visit Software Downloads in the Bentley CONNECT Center.
 SYNCHRO 4D Pro    SYNCHRO Scheduler  SYNCHRO Open Viewer     SYNCHRO Plugins
Back to Top
Improvements for Cloud-hosted 4D project through SYNCHRO Control
1.
Reduced performance issues when Windows is under a scan - in previous versions, programs like antivirus software might cause slowness while users were working on Control projects. Fixes are now in place to prevent noticeable slowness.
2.
Improvements on textures and other materials conversions – In some cases textures and 3D entity colors are now converted properly between Control projects and 4D Pro.
3.
Continue to improve near real-time collaboration experience –
  • Less wait when opening the project and downloading incoming transactions; wait time has been greatly reduced.
  • Animation conversion improvements – In some cases animations in 4D Pro were not matching animations in Control projects but are now synced.
  • Preparation for incremental sync on iModel-first projects – Incremental sync will greatly improve synchronization time from iModel, and this version is fully accustomed to supporting it.
  • Reduced constant popups of the reconnect dialog – to prevent the reconnect dialog from prompting and requiring users to manually clean up the project cache.
Back to Top
Major Features
1.
Upgraded plugins to support Revit 2025 and Navisworks Manage/Simulate 2025.
2.
Upgraded MicroStation plugin to support MicroStation CONNECT Edition 2024.
3.
3D Interoperability updates -
  • Navisworks: 2021-2025
  • Parasolid: up to v36
  • Revit: 2021-2025
  • Rhino: 4-8
  • SolidEdge: V19 - 20, ST - ST10, 2019 to 2024
  • SolidWorks: up to 2024
  • UGS JT: up to 10.9
  • Unigraphics NX: V11 to v18, NX to NX12, NX1847 Series to NX2312 PRT Series
4.
Replaced Oracle's Java Runtime Environment with OpenJDK.
5.
Introduced new unit: Diameter Inch.
6.
Drastically improved performance of the User Fields dialog.
7.
Asta PowerProject improvement - Bar name from Asta is now imported as a Task user field for improved interoperability; and separate from Task Names.
Back to Top
Minor Improvements
1. Updated Help documentation.
2. Updated distributed version of Bentley Connection Client.
3. Decreased memory usage for very large projects.
4. Introduced extra option for alternative IFC import (geometry only).
5. Updated EULA.
6. Improved Portuguese translations.
7. P6 import assigns unique Code Value names within the parent values.
8. Increased resource identifier limit from 20 to 40 characters.
9.  Security related 3rd party software upgrades.
Back to Top
Bugs squashed
• Some objects are dislocated and tilted after export to FBX
• Synchronize from Microsoft Project is unsuccessful
• The excel report exported from 4D pro is exporting incomplete data within a cell
• Export to MS project failure
• Export to Iray Error on specific single model
• Transform Manipulator doesn't stay with object when Edit as Assigned
• Specific model view (cranes) is distorted in Iray
• Rejected transaction P6 XML import
  Error synchronizing activity codes from Asta
• Assigned resource groups are not displayed after synchronization
• 3D Resources count is wrong at WBS level in Excel export
• Object imported by user is unchecked by default for other users in Control project
• Powerproject (Asta) to include Progress columns 'Percent complete' and 'Overall percent complete'.
• 4D Pro crashes importing specific MS Project XML
• Tasks are created in different order than selected resources order
• Shared includes are deleted too early, orphaning other references
• Mesh with material imports white and inconsistent results
• Grey zone is displayed in 3D view with both Static model and double precision rendering disabled
and more...
Back to Top
Resources
  1. Help documentation: press F1 to access directly in the product
  2. Training and Learning Resources
  3. System Requirements
Contact Details
Back to Top
