Pier Cap Transition Block
OpenBridge Modeler allows users to directly create a transition block on top of the caps to accommodate beams of different heights.  The Pier Cap Transition Block can be activated in the Substructure template by selecting the Transition Block toggle in the Cap tab.
More step-by-step information can be found at the link below from our OpenBridge YouTube Channel:
https://youtu.be/e3SL_0rrUeo?si=W-l47mkQMkLWmHHJ
