Template Studio Release Notes
The below information will take you through the updates that are specific to this application. For more general information and product update videos, please see the general New Release page.
v10.0.1.2461
Released 3rd May 2025
v10.0.1.2455
Released 29th April 2025
v10.0.1.2453
Released 22nd April 2025
v10.0.1.2447
Released 1st April 2025
v10.0.1.2430
Released 19th March 2025
v10.0.1.2423
Released 11th March 2025
v10.0.1.2419
Released 10th March 2025
v10.0.1.2386
Released 21st January 2025
v10.0.1.2381
Released 9th January 2025
v10.0.1.2379
Released 12th December 2024
v10.0.1.2376
Released 10th December 2024
v10.0.1.2369
v10.0.1.2363
Released 25th November 2024
v10.0.1.2357
Released 19th November 2024
v10.0.1.2353
Released 14th November 2024
v10.0.1.2344
Released 13th November 2024
v10.0.1.2334
Released 7th November 2024
v10.0.1.2331
Released 5th November 2024
v10.0.1.2318
Released 4th November 2024
v10.0.1.2305
Released 28th October 2024
v10.0.1.2295
Released 15th October 2024
v10.0.1.2231
Released 04th September 2024
v10.0.1.2185
Released 31st July 2024
v10.0.1.2174
Released 19th June 2024
v10.0.1.2163
Released 6th June 2024
v10.0.1.2157
Released 24th May 2024
v10.0.1.2135
Released 14th May 2024
v10.0.1.2129
Released 2nd May 2024
v10.0.1.2124
Released 30th April 2024
v10.0.1.2103
Released 23rd April 2024
v10.0.1.2091
Released 18th April 2024
v10.0.1.2082
Released 16th April 2024
v10.0.1.2071
Released 27th March 2024
v10.0.1.2065
Released 25th March 2024
v10.0.1.2025
Released 05th March 2024
v10.0.1.1988
Released 9th February 2024
v10.0.1.1973
Released 22nd January 2022
v10.0.1.1937
Released 12th January 2024
v10.0.1.1922
Released 15th December 2023
v10.0.1.1915
Released 12th December 2023
v10.0.1.1909
Released 6th November 2023
v10.0.1.1904
Released 5th December 2023
v10.0.1.1893
Released 30th November 2023
v10.0.1.1873
Released 14th November 2023
v10.0.1.1837
Released 20th October 2023
v10.0.1.1827
Released 9th October 2023
v10.0.1.1821
Released 5th October 2023
v10.0.1.1816
Released 28th September 2023
v10.0.1.1807
Released 11th September 2023
v10.0.1.1798
Released 6th September 2023
v10.0.1.1764
Released 8th August 2023
v10.0.1.1737
Released 19th July 2023
v10.0.1.1728
Released 13th July 2023
v10.0.1.1724
Released 5th July 2023
v10.0.1.1720
Released 30th June 2023
v10.0.1.1710
Released 15th June 2023
v10.0.1.1705
Released 14th June 2023
v10.0.1.1700
Released 12th June 2023
v10.0.1.1652
Released 15th May 2023
v10.0.1.641
Released 14th March 2023
v10.0.1.506
v10.0.1.489
Released 20th February 2023
v10.0.1.478
Released 19th January 2023
v10.0.1.475
Released 16th January 2023
v10.0.1.456
Released 8th November 2022
v10.0.1.451
Released 26th October 2022
v10.0.1.449
Released 12th October 2022
v10.0.1.424
Released 19th August 2022
v10.0.1.421
Released 13th July 2022
v10.0.1.416
Released 16th June 2022
v10.0.1.414
Released 31st May 2022
v10.0.1.408
Released 19th May 2022
v10.0.1.404
Released 13th May 2022
v10.0.1.397
Released 5th May 2022
v10.0.1.367
Released 17th February 2022
v10.0.1.361
Released 20th January 2022
v10.0.1.357
Released 12th November 2021
v10.0.1.354
Released 19th October 2021
v10.0.1.352
Released 28th September 2021
v10.0.1.348
Released 20th August 2020
v10.0.1.346
Released 06th August 2021
v10.0.1.336
Released 22nd June
v.10.0.1.291
Released 30th March 2021
v.10.0.1.273
Released 11th January 2021
v.10.0.1.264
Released 04th January 2021
v.10.0.1.257
Released 24th November 2020
v.10.0.1.252
Released 12th November 2020
v.10.0.1.244
Released 26th October 2020
v.10.0.1.240
Released 22nd October 2020
v.10.0.1.232
Released 14th October 2020
v.10.0.1.229
Released 25th September 2020
v.10.0.1.225
Released 12th August 2020
v.10.0.1.204
Released 02nd July 2020
v.10.0.1.196
Released 12th June 2020
v.10.0.1.193
Released 10th June 2020
v.10.0.1.187
Released 28th May 2020
Release of OpenGround Cloud
Released 25th April 2020
All of the notes below are relating to Keynetix.cloud and related products. These are included here for historic purposes.
v10.0.1.153
Released 30th March 2020
  • Added validation into the Dynamic Log dialog so that it will prevent preview if incorrect syntax is used in the expression dialog
  • Fixed a bug where if you had a blank Template Type in the Dynamic Template dialog it would crash. Now it asks for a valid entry
  • Fixed a bug where having small grids for a log follow on would previously show as medium
  • Fixed a bug which stopped logs from previewing when a strip hide condition was used.
v10.0.1.140
Released 26th February 2020
  • Improved first page/follow on template setup by adding greater precision to units per page.
    • field is now decimalised.
  • fixed a bug where scale wouldn't show the numbers under certain scale alignment settings
v10.0.1.136
Released 11th February 2020
  • Added a new feature for Headers and Footers called, First Page and Follow On.
    • The First Page Follow-on functionality allows for a different first page to be used compared to the rest of the log template. For example, this allows for a bigger header and footer area to be used on the first page of the log template, with a smaller area assigned to these on the following pages, allowing for more depth area to be shown.
v10.0.1.124
Released 21st January 2020
  • Fixed a bug affecting editing of tables causing the application to terminate.
v10.0.1.110
Released 13th December 2019
  • Fixed a bug with previewing site plans.
See user guide for information on how to use the new functionality by clicking here.
v10.0.1.108
Released 11th December 2019
  • This release contains addition of new template type called "Dynamic Templates"
v10.0.1.94
Released 29th November 2019
  • Updated App for change to API and enhanced Security
v10.0.1.83
Released 11th July 2019
  • Fixed display of connector symbols being used for range symbols on logs where previously if the connector carried on to the next page it would not be displayed. (Tile Y Selection only)
  • Fixed a bug with displaying the ground scale values correctly if the hole had any inclination values applied.
v10.0.1.81
Released 20th May 2019
  • Fixed a bug with quicklogs/log reports displaying. The bug would prevent previewing of the template where there was a vertical scale added which had the flag set for display ground level scale and the locations ground level was greater than 0 but less than 1.
  • Fixed a bug with combined logs displaying duplicate data for range text box items where the data is on the transition depth.
v10.0.1.78
Released 16th April 2019
  • Fixed a bug with combined logs displaying duplicated and squashed data when a straight line is used as the log transitions to next type.
  • Increased app security.
v10.0.1.74
Release 02nd April 2019
  • Fixed an bug with overwriting templates with the same name under the following scenario:
Borehole Log 1 saved as a standard Borehole Log Template.
Borehole Log 2 saved as Borehole Log 1 but as a Master Template.
The template will be overwritten but in Enterprise you will see two templates with the same name.
(please note that this change does mean that any template type saved with the same name as a different type of template will overwrite the previous one. For example saving a log as Test Log and a Site Plan as Test Log will mean the original log will be overwritten to become a site plan with the name Test Log.)
v10.0.1.72
Released 13th March 2019
  • Fixed an issue affecting the installer when used on Windows 7. App would not launch due to missing file in the installer package.
v10.0.1.70
Released 11st March 2019
  • App is updated be compatible with updates to the Keynetix.Cloud API
v10.0.1.65
Released 1st March 2019
  • Fixed an issue with saving changes to existing templates where the save dialog would hang.
v10.0.1.63
Released 28th February 2019
  • Improved the loading times of the template list. Retrieval of all available templates is now quicker.
v10.0.1.61
Released 28th January 2019
v10.0.1.59
Release 19th November 2018
  • App is updated to support the enhanced security changes to cloud infrastructure.
v10.0.1.58
Released 1st October 2018
  • Added Master Template Support.
  • Fixed a bug where the groups selection for creating filter groups wasnt displaying the names instead would be blank.
  • Fixed a bug where if you added a office field as a data label text but didnt have an office linked to the project Studio would display a record from the Location Details group.
  • The top bar will now show what cloud is currently being used.
