Civil 3D Extension Release Notes
The below information will take you through the updates that are specific to this application. For more general information and product update videos, please see the general New Release page
v.10.0.1.1703
Released 27th February 2025
v.10.0.1.1696
Released 21st January 2025
v.10.0.1.1690
Released 12th December 2024
v.10.0.1.1659
Released 25th April 2024
v.10.0.1.1656
Released 16th April 2024
v.10.0.1.1647
Released 26th February 2024
v.10.0.1.1640
Released 5th September 2023
v.10.0.1.1630
Released 30th June 2023
v.10.0.1.1617
Released 3rd May 2023
v.10.0.1.478
Released 28th February 2023
v.10.0.1.474
Released 10th January 2023
v.10.0.1.442
Released 8 October 2022
v.10.0.1.432
Released 12 October 2022
v.10.0.1.424
Released 22nd August 2022
v.10.0.1.418
Released 16th June 2022
v.10.0.1.414
Released 31st May 2022
v.10.0.1.406
Released 19th May 2022
v.10.0.1.404
Released 13th May 2022
v.10.0.1.395
Released 5th May 2022
v.10.0.1.391
Released 14th March 2022
v.10.0.1.389
Released 17th February 2022
v.10.0.1.382
Released 20th January 2022
v.10.0.1.379
Released 19th October 2021
v.10.0.1.370
Released 30th September 2021
v.10.0.1.366
Released 10th September 2021
v.10.0.1.361
Released 20th August 2021
v.10.0.1.346
Released 9th August 2021
v.10.0.1.335
Released 16th June 2021
v.10.0.1.299
Released 04th January 2021
v.10.0.1.296
Released 14th October 2020
.v.10.0.1.290
Released 2nd October 2020
v.10.0.1.271
Released 12th August 2020
v.10.0.1.259
Released 02nd July 2020
v.10.0.1.252
Released 28th May 2020
Release of OpenGround Cloud
Released 25th April 2020
All of the notes below are relating to Keynetix.cloud and related products. These are included here for historic purposes.
v.10.0.1.220
Released 30th March 2020
  • Fixed a bug where dynamic scale for graphs on strips wouldn't show correctly based on data being presented.
  • Fixed an issue with the audit history which would cause issues fetching updates.
v.10.0.1.198
Released 27th February 2020
  • Updated app in line with changes to api and security
v.10.0.1.190
Released 11th December 2019
v.10.0.1.187
Released 29th November 2019
  • Added ability to display plain and slotted pipe references for installations.
v.10.0.1.186
Released 20th November 2019
  • Fixed a bug where materials were not displayed in the hatch manager
v.10.0.1.179
Released 11th November 2019
  • Removed the database ID flag which for some cloud users who had their on premise databases merged and migrated to the cloud would not be able to connect their drawing files to their projects.
v.10.0.1.164
Released 19th September 2019
  • Added new USGS Hatch patterns which can be used in Enterprise when the following hbc is imported
v.10.0.1.160
Released 16th August 2019
  • Fixed a bug where profiles would crash on rebuild in certain circumstances due to invalid extends
v.10.0.1.152
Released 14rd May 2019
  • Fixed a bug with displaying strip headers for plan and profile view.
    • When data isnt present in one of the headers that header label would overlay on top of the header next to it which contain data.
    • Fix will hide strip headers where no data is present in them.
  • Improved error handling for fences when they crash on rebuild.
  • Fixed a bug where the can manage geotechnical layers role wasnt working correctly
v.10.0.1.144
Released 30th April 2019
  • Fixed a bug with CAD crashing on profile rebuilding under certain circumstances.
v.10.0.1.143
Released 23rd April 2019
  • Fixed an issue where CAD would crash on using the Geology Interpretation "follow" command in specific situations.
v.10.0.1.135
Released 16th April 2019
New Functionality added:
  • Persistence of Interpreted data is now possible (BETA)
    • Added Load and Save buttons.
    • Load- will allow users to create a Ground Model interpretation after edits as well as loading existing edits in a new drawing.
    • Save-will let users save what has been edited to an existing ground model interpretation or save a brand new one.
  • Added Follow and Trim functions.
    • Follow will copy the selected strata and use its interpretation for a different profile line by selecting a starting point and using the mouse to choose which side of the line to trim..
    • Trim is use for quick undo of a part of a selected profile line
  • Can also save non geotechnical profiles which can be restored to a new drawing. They are called supplementary profiles and can be found in the save menu.
Bug Fixes:
  • Improved handling of fences which have been modelled.
    • Prevention of application hanging in situations where fences have been modelled.
    • Improved error reporting by showing when fences fail to generate.
  • Improved app security.
v.10.0.1.134
Released 11th April 2019
Fixed an issue where in certain circumstances CAD would crash when rebuilding profiles.
Issue found in 2019 Civils.
v.10.0.1.127
Released 29th March 2019
Fixed a bug with displaying section strips where inclination was set as 0 in Enterprise. The plan view would show the inclination correctly but the section would flip it.
v.10.0.1.120
Released 11th March 2019
Fixed a bug where if data was added to the Orientation and Inclination table with empty record for Inclination Civils would treat it as 0 degrees. It is now treated as 90 degrees.
v.10.0.1.115
Released 13th February 2019
  • Fixed a bug where manually removing a borehole from a profile would remove all of them if the profile alignment was curved.
v.10.0.1.113
Released 11th February 2019
  • Enhanced geology modelling performance on the cloud.
v.10.0.1.109
Released 06th February 2019
  • Fixed a bug where profiles would crash if created using "other surfaces"
v.10.0.1.104
Released 28th January 2019
  • Added the option to create project level hatches and styles.
    • Hatches can be copied to the project edited and saved so they will be only used for that project, same with styles.
    • New Styles and Hatches can be created to be used within the project created in and not shared across all projects that share the same Configuration Pack..
    • Project level styles and Hatches can be copied to the Configuration pack
  • Fixed a bug where the Hatch Manager would show duplicate hatches if the same picklist name was used for a different geology type.
    • An example of this is CL used for Geology Code and cl used for Geology Code 2. CL would appear twice in the hatch manager but it is the same picklist so deleting one would remove both.
v.10.0.1.89
Released 19th November 2018
  • App is updated to support the enhanced security changes to cloud infrastructure.
v.10.0.1.88
Released 07th November 2018
  • Fixed a bug with rebuilding profiles which contain duplicate hatch names in use for separate geology references (e.g Legend Code or USCS)
  • Fixed an issue with hatches being displayed inconsistently in front or behind when dual graphics library items are used for the strips. (REGEN command needed after changes in 2017)
v.10.0.1.83
Released 01st October 2018
  • Fixed a bug where updating changes to the drawing made from HoleBASE Enterprise edits wouldnt be picked up immediately due to difference in time stamp from change made on the machine to the cloud server which could be in a different time zone.
v.10.0.1.80
Released 13th September 2018
  • Fixed a persistent CAD crash issue when connecting to a Project in Civils.
    • Civils 2017 was affected by this crash. 2018 and 2019 were unaffected.
v10.0.1.67
Released July 2018
  • Improvements made to the opening speed of the ribbon buttons.
  • Added the Geology modelling interpretation to Cloud Civils
