The below information will take you through the updates that are specific to this application. For more general information and product update videos, please see the general New Release page.
v10.0.1.1828
Released 9th June 2025
- Bug fix for report generation not working correctly or populating project info
v10.0.1.1821
Released 2nd June 2025
- Fixed a bug where saving a generated report as a local workbook removed the report
v10.0.1.1815
Released 26th March 2025
- Bug fix to enable to addition/removal of system level tables
- Security vulnerability enhancements
v10.0.1.1803
Released 11th March 2025
- Bug fixed for token refresh where it signed user out and crashed when attempted to sign back in
v10.0.1.1793
Released 27th February 2025
v10.0.1.1778
Released 21st January 2025
- Fixed bug with running reports and opening projects
v10.0.1.1778
Released 11th December 2024
v10.0.1.1767
Released 19th November 2024
v10.0.1.1757
Released 15th October 2024
v10.0.1.1750
Released 29th August 2024
v10.0.1.1747
Released 28th August 2024
- Fixed an issue where the report would crash if it there was a custom header for depth link top or depth link base.
v10.0.1.1722
Released 2nd May 2024
- Fixed an issue where the Excel Extension wouldn't open if Datgel Toolbox was installed.
- Fixed a bug where the report would crash if it included a custom group without any headers.
v10.0.1.1706
Released 26th February 2024
- App updated to support future OpenGround release of Report Options.
v10.0.1.1692
Released 12th January 2024
v10.0.1.1686
Released 01st December 2023
- Fixed a bug with filtering on custom date field thats a string
v10.0.1.1683
Released 19th October 2023
- An app update to ensure compatibility with future features
v10.0.1.1676
Released 11th September 2023
- Bug fix for not being able to filter if custom field is a picklist
v10.0.1.1671
Released 5th September 2023
- Bug fix to show a message when a user is trying to open the app on a cloud where the user is not active in.
v10.0.1.1658
Released 8th August 2023
v10.0.1.1646
Released 30th June 2023
v10.0.1.1640
Released 16th June 2023
- Fixed a bug where it was not possible to save a report to a project or a config pack
v10.0.1.1626
Released 17th May 2023
- Fixed a bug with generating templates with a filter using new schema config packs
- Fixed a bug with reports not generating correct graph line styles
v10.0.1.320
Released 9th January 2023
- Displaying a banner to access US government clouds
- Prompt user re-authentication after period of inactivity
- Fixed a bug with Excel extension crashing on loading
v10.0.1.316
Released 30th November 2022
- Fixed a bug where Excel would close when run due to a TLS registry issue
v10.0.1.280
Released 12th October 2022
- FIPS compliant app update
v10.0.1.265
Released 28th July 2022
- Fixed a bug with ability to run reports
- Fixed a bug with saving reports after editing
v10.0.1.259
Released 16th June 2022
- App updated after config pack model enhancements
v10.0.1.257
Released 31st May 2022
- Fixed a longstanding issue with authentication of the app due to newtonsoft installation
v10.0.1.249
Released 19th May 2022
- Updated app due to mandatory update for data collector update 3
v.10.0.1.241
Released 5th May 2022
- Updated app in line with security update to infrastructure
v.10.0.1.237
Released 19th April 2022
- Fixed a bug with report generation where the project had a lot of location groups with filtering set up
v.10.0.1.235
Released 14th March 2022
- Fixed a bug where reports would crash if a field being used was of the integer data type
v.10.0.1.233
Released 17th February 2022
- Updated app in line with infrastructure improvements
v.10.0.1.217
- Fixed an issue which prevented office/project logo images from being displayed on reports
v.10.0.1.215
Released 20th September 2020
- Fixed bug where if user had previously uploaded a non image to template images dialog in Pro this would cause the same crash in Excel Extension
v.10.0.1.205
Released 9th August 2021
- App updated to support the migration to Azure Cloud Infrastructure.
v.10.0.1.175
Released 04th January 2021
- This update contains the database model updates for AGS 4.0.4 changes. These changes have been communicated in the following communities article:
v.10.0.1.171
- Fixed a bug which could cause a loss of the template during the save routine.
v.10.0.1.169
Released 12th August 2020
- App updated in line with updates to OpenGround Cloud API
- Mulit Grid Support from OpenGround Cloud Professional
v.10.0.1.147
Released 10th June 2020
- Added improvements for Authentication when app is open but logged out of launcher
v.10.0.1.142
Released 28th May 2020
- Fixed the link to Bentley Cookies page which didn't go to the correct site.
- general performance and stability updates
Release of OpenGround Cloud
Released 25th April 2020
- Release of OpenGround Cloud and related applications
All of the notes below are relating to Keynetix.cloud and related products. These are included here for historic purposes.
v10.0.1.83
Released 27th February 2020
- App is updated be compatible with updates to the Keynetix.Cloud API. Increased app security.
v10.0.1.78
Released 11th December 2019
v10.0.1.71
Released 29th November 2019
v10.0.1.60
Released 16th March 2019
v10.0.1.58
Released 11th March 2019
v10.0.1.55
Released 28th January 2019
v10.0.1.54
Released 19th November 2018
- App is updated to support the enhanced security changes to cloud infrastructure.
v10.0.1.52
Released 1st October 2018
- Fixed a bug where adding an office related field into a report where the office is not linked to the project would cause an error to occur.
