This article contains Download links and Change Logs for current and legacy standard Configuration Packs.
For more information on the Version and Key Names, please see this article.
Configuration Pack Guides can be found here.
Individual Components, such as example templates, can be downloaded here.
| Configuration Pack | Guide | Version |
| Australia | Australia | AUS_02.01 |
| North America Metric | North American Metric | NAM_02.01.01 |
| UK | United Kingdom | UK_02.01 |
| US | United States | US_02.01.01 |
| LAB | Lab Guide | LAB |
| Version | Key Name | Change Log |
| AUS_02.01 | Australia |
Added import/export support for AGS 4.1.1 AU 1.2. Updated standard data model to reflect: Updated mapping files and other components to reflect changes in the data model. |
| AUS_01.04 | Australia |
Repaired Grid View filters. |
| AUS_01.03 | Australia |
This version has been removed after an issue was found within the download file. (Grid View filters did not export.) Added Charts Point Symbols. |
| AUS_01.02 | Australia |
This version has been removed after an issue was found within the download file. (Grid View filters did not export.) Added WSTK2 & WSTK3 Point Symbols. Added NorthArrow Template Image. (Most updates for this iteration were made within the US and North America Metric config packs.) |
| AUS_01.01 | Australia | First version after introduction of version numbering. |
| - | Oceania | Versions prior to introduction of version numbering. |
| NAM_02.01.01 | North America Metric |
Fixed an issue where Project Sheet - Lab Summary - US wouldn't generate due to references to renamed D# headers. |
| NAM_02.01 | North America Metric |
| NAM_01.04 | North America Metric |
| NAM_01.03 | North America Metric |
This version has been removed after an issue was found within the download file. (Grid View filters did not export.) Updated Grid Interval and Axis Tick expressions on Quick Sections to better handle deep and long sections. Added Charts Point Symbols. Added several Chart template examples (lab reports). Updated Description expression on Lab Summary template. |
| NAM_01.02 | North America Metric |
This version has been removed after an issue was found within the download file. (Grid View filters did not export.) Made separate Steps for Non-Component, Soil Component & Rock Component Descriptions in Data Entry Profiles. Moved "Lab Sample Information" Step to end of Logging Data Entry Profiles and made miscellaneous adjustments to help distinguish logging of "Sampling Activities" vs. "Lab Samples". De-activated "Lab Index & Strength Test Data" Data Entry Profile. (Lab Data Entry is currently easiest to enter in Portal Project Explorer). Removed Recovery from Sample Information grids (Data Entry & Explorer) with the intention that Recovery information should be entered in the "Sampling Activity" Groups. For simplification purposes, changed the standard Strip Sets to use "Strip - Sampling Activity Type and Number". Also removed Sample Information from this Strip. Removed Sample Information from the Sampling Activity column in "Strip - Sampling Activity Type and Sample Number". Similarly, removed Sample Information from the "Strip - Recovery RQD" template. Deleted a few of the Sample Strip variations for simplification purposes. Removed Sample Information Recovery headers from Data Collector profile. De-activated additional Groups to help streamline the Project Explorer. Updated SPT Reported Result model calculation to better handle tests ended with blows at 150 or 300-mm penetration and no advancement. Added Project Options and Location Options to control the Units Per Page for the Default and CPT Master Templates. Updated Strips to use PointDataText, RangeDataText, and BoundaryLines. Replaced StraightLine objects for FinalDepth within Strips with BoundaryLines. Updated templates to use True Font Sizes. Removed column footer borders in Strip templates to clean up appearance when footer is used as 'overflow area' when scale being used doesn't fit precisely in the depth area. Made some adjustments and fixes to CPT Log Strips. Deleted "Strip - Lab Results Concatenated" and "Strip - Tests and Remarks". Replaced these with "Strip - Lab Tests" and "Strip - Field Tests and Remarks". (This keeps data related to Samples in one strip and data not directly related to Samples in another Strip, which works better in some scenarios, such as using Boundary Lines.) Deleted "Strip - Fines Content w PSD Data Lookup" and incorporated lookup behavior into "Strip - Fines Content" Deleted "Strip - Graphic Log - Legend Code w Color Code" and updated Strip Sets & "Strip - Graphic Log - Legend Code" accordingly (a separate Strip is no longer needed to color code graphics). Removed "Simple-" prefix from StratumDetails - ColorCode picklist values. Fixed header font size for Torvane strip. Added "Project Sheet - Key To Symbols" template. Added calculated "Type Reported" headers in SPT and Coring groups. These return a default Type if a Type isn't entered. This makes it so that symbols appear in Legend Blocks. Updated Sampling Activity strips accordingly to reference the Type Reported headers. Added "SPT" to SPT test type picklist. Added an example Lab Summary Project Sheet. Added Quick Section Strip Profiles. Added a custom Remarks header to the SectionDetails group. Added a custom SoilBehaviorType header to the StaticConePenetrationData group. Removed previous Quick Section templates and replaced with 1 Legacy Quick Section Template and 2 new Quick Section templates (Letter & Ledger paper sizes). Modified Quick Section Strips. Updated "Strip - Well Installation Details" to only shown Pipe Height/Elevation on first page and to use aggregation to report for multiple installations. Changed Bar Chart Grid Lines style on "Strip - Dynamic Probe Blows" and added line at hole depth. Deleted Dynamic Probe Torque Strip. Added a "z_StripReview - ANSI-D Landscape" template intended for reviewing all Strips available within the config pack. Incorporated this template into the "Template Format Review" Report Profile. Removed extraneous Filter Groups from Well Strips. Updated Well Strips to use Smart Pointers and Callouts. Removed Well Strips from Geotech Strip Sets. Changed some Backfill Legend Code images. Added WSTK2 & WSTK3 Point Symbols. Added Pipe Cover to Well-Installation Data Entry Grid. Added NorthArrow Template Image. Added North Arrow to Site Plan template. |
| NAM_01.01 | North America Metric | First version after introduction of version numbering. |
| - | North America | Versions prior to introduction of version numbering. |
| UK_02.01 | UK |
Updated standard data model to reflect: Updated mapping files and other components to reflect changes in the data model. Fixed an issue with Civil 3D template references. |
| UK_01.04 | UK |
| UK_01.03 | UK |
| UK_01.02 | UK |
| UK_01.01 | UK | First version after introduction of version numbering. |
| - | Great Britain | Versions prior to introduction of version numbering. |
| US_02.01.01 | US |
| US_02.01 | US |
| US_01.04 | US |
| US_01.03 | US |
This version has been removed after an issue was found within the download file. (Grid View filters did not export.) Updated Grid Interval and Axis Tick expressions on Quick Section Templates to use 1-inch intervals with Imperial scales. Updated Quick Section Templates to use Imperial scales. Added Charts Point Symbols. Added several Chart template examples (lab reports). Updated Description expression on Lab Summary template. |
| US_01.02 | US |
This version has been removed after an issue was found within the download file. (Grid View filters did not export.) Made separate Steps for Non-Component, Soil Component & Rock Component Descriptions in Data Entry Profiles. Moved "Lab Sample Information" Step to end of Logging Data Entry Profiles and made miscellaneous adjustments to help distinguish logging of "Sampling Activities" vs. "Lab Samples". De-activated "Lab Index & Strength Test Data" Data Entry Profile. (Lab Data Entry is currently easiest to enter in Portal Project Explorer). Removed Recovery from Sample Information grids (Data Entry & Explorer) with the intention that Recovery information should be entered in the "Sampling Activity" Groups. For simplification purposes, changed the standard Strip Sets to use "Strip - Sampling Activity Type and Number". Also removed Sample Information from this Strip. Removed Sample Information from the Sampling Activity column in "Strip - Sampling Activity Type and Sample Number". Similarly, removed Sample Information from the "Strip - Recovery RQD" template. Deleted a few of the Sample Strip variations for simplification purposes. Removed Sample Information Recovery headers from Data Collector profile. De-activated additional Groups to help streamline the Project Explorer. Updated SPT Reported Result model calculation to better handle tests ended with blows at 6 or 12-mm penetration and no advancement. Added Project Options and Location Options to control the Units Per Page for the Default and CPT Master Templates. Updated Strips to use PointDataText, RangeDataText, and BoundaryLines. Replaced StraightLine objects for FinalDepth within Strips with BoundaryLines. Updated templates to use True Font Sizes. Removed column footer borders in Strip templates to clean up appearance when footer is used as 'overflow area' when scale being used doesn't fit precisely in the depth area. Made some adjustments and fixes to CPT Log Strips. Deleted "Strip - Lab Results Concatenated" and "Strip - Tests and Remarks". Replaced these with "Strip - Lab Tests" and "Strip - Field Tests and Remarks". (This keeps data related to Samples in one strip and data not directly related to Samples in another Strip, which works better in some scenarios, such as using Boundary Lines.) Deleted "Strip - Fines Content w PSD Data Lookup" and incorporated lookup behavior into "Strip - Fines Content" Deleted "Strip - Graphic Log - Legend Code w Color Code" and updated Strip Sets & "Strip - Graphic Log - Legend Code" accordingly (a separate Strip is no longer needed to color code graphics). Removed "Simple-" prefix from StratumDetails - ColorCode picklist values. Fixed header font size for Torvane strip. Added "Project Sheet - Key To Symbols" template. Added calculated "Type Reported" headers in SPT and Coring groups. These return a default Type if a Type isn't entered. This makes it so that symbols appear in Legend Blocks. Updated Sampling Activity strips accordingly to reference the Type Reported headers. Added "SPT" to SPT test type picklist. Added an example Lab Summary Project Sheet. Added Quick Section Strip Profiles. Added a custom Remarks header to the SectionDetails group. Added a custom SoilBehaviorType header to the StaticConePenetrationData group. Removed previous Quick Section templates and replaced with 1 Legacy Quick Section Template and 2 new Quick Section templates (Letter & Ledger paper sizes). Modified Quick Section Strips. Updated "Strip - Well Installation Details" to only shown Pipe Height/Elevation on first page and to use aggregation to report for multiple installations. Changed Bar Chart Grid Lines style on "Strip - Dynamic Probe Blows" and added line at hole depth. Deleted Dynamic Probe Torque Strip. Added a "z_StripReview - ANSI-D Landscape" template intended for reviewing all Strips available within the config pack. Incorporated this template into the "Template Format Review" Report Profile. Removed extraneous Filter Groups from Well Strips. Updated Well Strips to use Smart Pointers and Callouts. Removed Well Strips from Geotech Strip Sets. Changed some Backfill Legend Code images. Added WSTK2 & WSTK3 Point Symbols. Added Pipe Cover to Well-Installation Data Entry Grid. Added NorthArrow Template Image. Added North Arrow to Site Plan template. |
| US_01.01 | US | First version after introduction of version numbering. |
| - | US | Versions prior to introduction of version numbering. |
| Configuration Pack | Key Name |
| ASTM I - American Default | ASTM I - American Default |
| ASTM M - American Metric | ASTM M - American Metric |
| Australian Default | AUS - Australian Default |
| British Standard | British Standard - Default |
