The Report Profiles define which templates are associated with each location type. The Report Profiles are defined either at a project level (under the Configuration ribbon) or within a Configuration Pack.
- Select the Report Profiles option from the ribbon.
- Use the interface to Add or Edit a profile as appropriate.
- The report profile summary will then appear. Ensure the Report Profile has a name defined and for each required hole type expand the list of associated templates. Note that a Default Profile can be nominated.
- Add additional templates for each hole type and set the expected orientation, scale, and paper size.
- Check the box for Default Profile if appropriate. Click Save to complete the creation of the Report Profile.
