Units have their own unique interface to allow for easier access and management. To configure the units available within the project, select the Manage Units option from the Configuration tab of the ribbon.
The Edit Pick List Group screen will then appear with the units shown.
The Units interface works in the same way as the way standard Picklists do. Therefore, for further information on the way Picklists function. See the Picklists section of this guide.
