At any time during the data entry process you can view the borehole log by clicking on the Quick Log button on the main Ribbon. This will display the quick log form and toolbar and give you access to all the log previewing features of the main OpenGround Cloud application.
The default log that is displayed will be the default template setup for the location type in the main OpenGround Cloud project / config pack configuration > manage templates (i.e., the same defaults that are setup for Quick Logs). You can print the logs and/or save via pdf if you wish to much like you can using OpenGround Cloud, you can also use the zoom functions and set log orientation using the appropriate tabs.
