If you have a problem with the software then please log a support ticket using the Product Support page - please select the relevant product in the product dropdown list as this will ensure that the ticket gets assigned to the correct team and will speed up your response.
To enable for us to support you as best as possible, please ensure that you include all of the following in your request;
Also, after a ticket is filed in and you have started engaging with the support team, if you are expecting feedback and do not get anything; please check your junk emails inbox as some systems may flag emails originating from the Bentley support team.
