- Silent Installation
Bentley Map can be installed with no user interaction. A command prompt is used with reference to the .msi file location. Parameters are defined to set the installation directory and the workspace directory locations.
The following is an example of a prompt used to install Bentley Map V8i:
C:\Users\user>C:\Windows\System32\msiexec /l*v c:\users\user\silent.log /qr APPL
ICATIONFOLDER="C:\Program Files (x86)\Bentley\MapSilent" PACKAGE_HOMEROOT="C:\Pr
ogram Files (x86)\Bentley\MapSilent\Workspace" /i "C:\BentleyDownloads\bm0811095
03en\install\BentleyMap.msi"
For additional information, please refer to:
Installing MicroStation Silently
