01. Capability to design the Flexible shell element in AutoPIPE Vessel?
02. Does AutoPIPE Vessel consider cone-shell junction as line of support for external pressure calculation?
03. How do I control whether or not use stiffener for external pressure?
04. Modelling a dummy shell
05. Determination of length of shell in a heat exchanger
