CONNECTION Clientプロンプトを抑える方法
Product(s):CONNECTION Client
Version(s):
Area:
CONNECTION Client prompts login window even if user logged out the window and do not wish to login it.
There is currently no elegant way to suppress CONNECTION Client completely, but you can modify a configuration file to eliminate the hourly popups of the CONNECTION Client window since an end user will not be able to sign in. To do so, please perform the following steps:
Open "C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\Bentley.Connect.Client.exe.config" in a text editor.
Do a search for PopupIntervalMinutes.
 <add key="PopupIntervalMinutes" value="60" />
Change the value from 60 to 1440 so that CONNECTION Client only prompts the end user once per day.
Unless running the text editor as an administrator, save a copy to another location.
Replace the original with the modified copy, and exercise administrator privileges when prompted.
Other Language Sources
Deutsch
Italiano
