Applies To | |
Product(s): | AutoPIPE Vessel |
Version(s): | ALL |
Area: | |
Date Logged & Current Version | March 2020 41.04.00.013 |
How to delete an existing material from the database?
Select the material and click on Erase, then click on Write database. Alternately you can query and click on Delete Found and Write Database.
