04. How to create a small material database for a few select list of materials and merge it to anoth
Product(s):AutoPIPE Vessel
Version(s):ALL
Area:
Date Logged
& Current Version
March 2020
41.04.00.013
Problem:
How to create a small material database for a few select list of materials and merge it to another database?
Creating a small material database is very useful since it can be easily transmitted by email and also be conveniently loaded or merged to an existing database, which is explained below.
 As an example we would create a material database for ONLY SA 738 materials grades A, B and C.
1. Open the “Material Database Dialog” (Execute>Manage Material Database)
2. Modify the norm of the applicable materials eg. SA 738 Grade A
3. Make a query to select your materials:
This would query only the SA 738 materials since ONLY they have Norm ASME 2 and not ASME II
 4.  Create a new material database file including your materials (eg. SA 738) only:
 5.  Load your new database file and restore the correct Norm:
 6. Save your changes
7. Merge this new small database with existing one
AutoPIPE Vessel
Bentley LEARN Server
