01. "Not a valid Material Database load it manually" message appears when using AutoPIPE Vessel, why
Product(s):AutoPIPE Vessel
Version(s):ALL
Area:Material Database
Date Logged
& Current Version
March 2020
41.04.00.013
Problem:
When we open Autopipe, the following is displayed
OK
When we try to load it manually, it says not a valid Material Database, load it manually
According to the screenshot, it seems that:
1.An old release is used (v40.01.00.09)
2.The material file is located on a distant machine (E:\...)
 So, We recommend to follow the steps mentioned below.
1.Uninstall all versions of AutoPIPE Vessel.
2.Delete all files under “Puser1” folder (by default here: C:\Users\Public\Documents\AutoPIPE Vessel_40.xx.xx.xx)
3.Install a more recent release, without changing the default pathnames.
4.Launch AutoPIPE Vessel and open an example model file to confirm the solution has worked.
AutoPIPE Vessel
Bentley LEARN Server
