Product(s): | MicroStation | ||
Version(s): | CE update13 | ||
Environment: | N\A | ||
Area: | Programming | ||
Subarea: | MDL |
bmake, make file のマクロ記述については、
C:\Program Files\Bentley\MicroStationCONNECTSDK\Documentation\MicroStationAPI.chm の
Modules>Contents & Articles>Getting Started>Building Application>Creating a Makefile and Using the bmake Utility に記載されています。
Original Author: | Mikihiko Tabata |
