Applies To | |
Product(s): | AutoPIPE |
Version(s): | ALL; |
Area: | all |
Date Logged & Current Version | July 2020 12.03.00.17 |
Can AutoPIPE create a model from an ISM file?
At this time, July 2020, AutoPIPE can only import structural information from an ISM model. All other ISM information (piping, foundations, geo, etc..) will be ignored.
The user could import structural information from the ISM file into AutoPIPE and then add piping information as needed. This model can then be saved as an AutoPIPE DAT / APC file or exported out to a supported file format.
Note, applications are constantly being updated, check the current version of AutoPIPE to be sure this statement still holds true.
ISM files imported into AutoPIPE
