"The value should be in range 0.010 to 10.000"... message appears when using AutoPIPE, why?
Product(s):AutoPIPE
Version(s):ALL;
Area: Message
Date Logged
& Current Version
March 2020
12.02.00.14
Problem:
"The value should be in range 0.010 to 10.000.".. message appears when trying to enter in Soil data in AutoPIPE,
OK
why?
 The following Soil Overburden Loads values must have the range of 0.010 to 10.000:
- Deflection lag factor DI
- Bedding constant K
- Soil support factor Fs
Otherwise the message above will be displayed.
"Bentley AutoPIPE" Messages
