You will now see the connected Work Areas in a folder hierarchy, just like in ProjectWise Explorer, on the left side panel of PW Web. You can navigate through folders and access Saved Searched more easily. As you navigate folders, the Views applied to those folders will be displayed in the grid configuration, UNLESS you have applied a personal "My View" already. In that case, My View will override the folder view. You can revert back to the folder view by choosing Display Folder Global View. See Managing Views to learn more about the views available in ProjectWise Web.
Navigating the Information Panel; Details, Attributes, Audit Trail Tabs
To view the properties of a file or folder, select the checkbox next to the item and click the properties icon. The properties pane displays. For folders, the pane displays the Date Created and the Last Modified date. For files, the pane can display more properties including detailed information like Status, Created, Last Modified, Environment Attributes (Editable attributes requires WSG ProjectWise Plug-in 3.3), and Audit Trail information . If you select multiple items, the properties pane displays the number of items selected. To close the properties pane, click the X in the top right of the pane.
Edit attributes one document at a time:
Or, edit multiple documents simultaneously:
View Audit trail:
