LOAD CONDITION NOT FOUND IN S FILE
Question: SACS run shows an error as LOAD CONDITION “XXX” NOT FOUND ON S FILE TYPE”
Solution: In the SACS secondary file, under LDOPT line go to Column 65-67. In line assistant you will see SACS asks, “Combined Loads to Basic Option”. You need to select “Yes” in this option. Thus, the error will be rectified.
