Overview: This is intended to explain the recommended deployment setup for a WSG server with the WSG plugin version 10.00.03.436 and higher.
Products and versions:
- ProjectWise Web Services Gateway 02.06.08.09
- ProjectWise Design Integration Plugin for WSG Connect Edition 10.00.03.436 and higher.
- What Bentley software should be deployed on the Web Services Gateway Server?
- ProjectWise Explorer 10.00.03.336 (prerequisite)
- ProjectWise Design Integration Plugin for WSG Connect Edition 10.00.03.436 or higher.
- What are the minimum hardware requirements for a Web Services Gateway Server deployment?
- https://docs.bentley.com/LiveContent/web/ProjectWise%20Readme-v8/en/GUID-A685A10A-5108-49A4-81EE-9C3DD903B99D.html
Operating System
Unless noted, all ProjectWise servers and clients are supported on these 64-bit server operating systems:
- Windows Server 2019, Standard and Datacenter Editions
- Windows Server 2016, Standard and Datacenter Editions
- Windows Server 2012 R2, Standard and Datacenter Editions
- Windows Server 2008 R2 SP1, Standard and Enterprise Editions
Unless noted, all ProjectWise client applications are supported on these 64-bit client operating systems:
- Windows 10
- Windows 8.1
- Windows 7 SP1
Virtualization Software
ProjectWise is supported for use in virtual environments; however, Bentley does not certify ProjectWise on any specific virtualization software. While ProjectWise testing is regularly performed using virtualization software, the individual ProjectWise applications are tested with a focus on the operating system, not the specific virtualization software running the operating system.
ProjectWise Design Integration Server Requirements
- 2 GHz x64 processor or better, dual-core or multiple-processor architecture is strongly recommended
- 8 GB of RAM or more recommended
- 500 MB of free hard disk space for installation, plus adequate space for file storage (depending on number and size of files) if this server will host a storage area
- Windows server operating system:
Notes
For ProjectWise Web Services Gateway to function correctly with any WSG plugin later than version 10.00.03.336 , You must not have any other PWDI (ProjectWise Design Integration) server software installed on the same server as the WSG plugin.
